Hels13
Everything posted by Hels13
  1. Thank you, yes that would make sense. Off to Screwfix 👍
  2. Hi all, My toilet cistern has all of a sudden started over filling. The ball cock is at its lowest. When we flush, after about a minute, water starts draining into the overflow and water is leaking from the inlet valve. Any ideas what could be the cause? And what solutions I could try please?
  3. I'm planning on filling in and sanding down the holes, then wood stain on top, white on risers, possibly a carpet runner down middle. Thanks for the advice 👍
  4. Hi all, I've been trying to fix my creaky stairs (no access from underneath unfortunately). I've screwed down the treads and screwed through the back of the treads into the risers, adding some wood glue as I went (pics attached). Unfortunately, it seems they're still creaking (albeit a little less) and I'm all out of ideas. Any thoughts?
  5. Evening all, I've just noticed tonight my waste pipe was leaking under the kitchen cupboard. I've reconnected them all, but the pipe that connects to the half sink keeps popping back off amd dropping down. Could an easy solution to be to replace the downward pipe circled in picture with a longer pipe? If so, what type of fitting would thus be called? Thanks, Helen
  6. Me again! I've recently had a porcelain patio laid with sandy colour grout. He was wetting the slabs while putting the grout on, but some has come away from the joints (he's coming back Monday to fix this). However, there now seems to be a lot of staining on my tiles from washing the excess grout away. Is there an effective way to clean these properly please? Last pic is what colour they should be.
  7. Evening all, I've just had a new patio laid, and I keep finding little snags. One issue I'm not sure about though, is whether they've left enough of a gap between the patio and the vent at the base of my house. I'm not sure what the regs are, but I'm worried that water will drain in easily and start to cause damp issues. Does this look OK, or should I be concerned? Thanks, Helen
  8. Thank you so much, never found either of these in my Google searches.
  9. Hi all, Does anyone know where I could find patio slabs similar to the attached picture please? I've trued all the usual builders merchants and retailers, but nothing as similar to these. Thanks in advance, Hels
