sonicboom
Everything posted by sonicboom
  1. Interesting, so the mvhr is passively heating that room. It is impressive whatever the case - 0.75c between exhaust/inlet which would make it 97% efficient ? Seems too good to be true. What make/model is your unit ? and what is the flow rate ? 18c is freezing btw, don't know how you survive.
  2. Thanks - what is your internal temp ?
  3. In my experience I have found wool insulation insufficient for pipework, primarily because its not dense and air can flow through it. I had some metal pipework that was losing huge amounts of heat under wool - 25mm pipe insulation fixed it.
  4. Its currently running on its lowest speed. The house has a stale air smell in some rooms due to them being too tight. Speed 2 helps (there are 6 settings) but it gets very cold very quickly.
  5. The house is a little too tight for extractors and PIV hence MVHR - The PIV is not as effective as it used to be and the improvements in heat retention just make it very costly to run.
  6. Not bad 18.5c would be 92% if I maths is correct - Although, for 6.5c, I was expecting the efficiency to be a little higher. What does the WARM setting do ?
  7. 15c? that's a lot of heat loss, haven't you insulated your runs ? or maybe not enough ? what kind of duct work are you using ?
  8. I am planning on upgrading my 10 year old PIV system to an MVHR. What kinds of efficiencies should I expect at current temperatures (-2.5c). My PIV churns out a draughty 7c and that is with the 400w heater enabled. i would ideally like something above 19c (internal temp is 22c 24/7). I have my eyes on the Zehnder Q350 which goes up to 96% but they do not produce charts on how that performance degrades as the temperature drops.
