Hello
I feel a bit of a fraud as I am not actually doing my own project, but after looking at a few forums, this one seemed to be about the best for technical advice on heat pumps, so I hope I can be indulged. Our position is we are having an air to water heat pump system installed, fully funded by government grant (so we have no choice of installer). They say they will be installing a Vaillant 5kW monobloc, a Joule 150L high gain slimline tank and 7 radiators. There is no existing wet central heating, only Fischer radiators. In their design they have used an oversize factor of 1.9. If I am reading the MCS design guidelines correctly, to be in the green zone with normal emitters the minimum factor is 2.4. They have assumed a flow temperature of 55, which as I understand it is when the heat pump is at its most inefficient, and even then according to their own figures this will be insufficient to heat some of the rooms because they will only use standard radiator sizes, ie K2 and 600mm high. I am thinking that in the future we will want to change some or all of the radiators. So in the longer term I might be looking for advice on how to go about that. In the shorter term I will be looking for advice on setting the system up, because I don't expect them to spend too much time on that. I am guessing it will be the most basic control system, so also perhaps advice on upgrading. In the immediate term, I will be looking for advice on what to look for on things like pipework sizes, etc.
