Robert Clark
Everything posted by Robert Clark
  1. Hi Guys Planning a mini refurb of our shower cubicle without re tiling the whole bathroom. The plan is to replace the leaky shower mixer with an exposed bar mixer. Replace the shower enclosure too. Then fit two Multipanel panels over the existing tiles. The question is: If I fit the wall panels under the shower screen will the end trims of the panel throw the shower screen trim out of square? Would it be better to butt the wall panel up against the wall panel? Thanks
  2. Hi Guys Can you please help me with a couple of budget prices? Individual prices please for; Demolish and re build a 4 pipe chimney above the roof. It’s max 2 m high. Materials and labour, excluding scaffold cost. Remove 4m load bearing wall (with chimney) between two rooms on ground floor. Including steels and making good. Job is in East Sussex and forms part of a larger refurb and extension project. Thanks
  3. The capacitor has just arrived and the pump works ! Might have saved me £300! Thanks very much !
  4. Sorry I meant 2.5mm this is the box it came in it just looks a bit thin compared with the cable that was used for the ring main
  5. Hi Guys Is 1.5mm cable ok for supplying a spur to a double power point? Thanks
  6. Dimensions are close thanks Any idea how to release the existing wires ?
  7. Found a better one (I think) on EBay https://www.ebay.co.uk/itm/273634770355
  8. Is this the same thing?
  9. Looks like the inlet / outlet connections are narrower than a regular pump
  10. Hi Guys Looks like my Grundfos Solar 15-65 pump has packed up. Its making a buzzing noise, the body is red hot but it’s not pumping. Ive removed the large screw cap and turned the spindle, which appears to move. Any ideas how I can fix it? An identical replacement is £300, and I was wondering if a regular central heating pump would be a suitable replacement Thanks
  11. Hi Guys Im replacing the rotten timber cladding on my shed with composite cladding. What is the best way to measure and cut the cladding to get a nice tight fit against the sloping roof? As you can probably guess, carpentry isn’t my best skill. Thanks
  12. Do they supply DIY ?
  13. Where did you buy them from ?
  14. Hi Guys Is it possible to apply wall panels over existing tiling? Which are the best type of panels for ease of installation and quality? Thanks
  15. Sorry I gave you the link to the B rated one This is the A rated one https://www.ebay.co.uk/itm/113535196260
  16. https://www.ebay.co.uk/itm/113257154128
  17. £395 inc VAT and delivery Theyve only got 150 litre ones though which is fine for the two of us
  18. Our new (imperfect) OSO cylinder bought on EBay (from OSO) saving over £500 was fitted yesterday. Heated up really fast well pleased !
  19. A bit too high end for me thanks . Cladco appears to sell an identical product for £37.92 pm compared with £41.39 from Envirobuild
  20. Looking for some black rigid composite cladding at a reasonable price. Any suggestions would be appreciated Thanks
  21. How much do you think per day?
  22. Hi Guys How much do you think for labour only to fit an unvented cylinder in a first floor airing cupboard ? All pipe work other than the external pressure relief pipes are already there. There is nothing to remove. Job is in Sussex Have been quoted £700 labour (not vat registered) plus materials. Thanks
  23. I did decide against it as I will be using using the cylinder for a number of years without any thermostat or solar PV input. A smart cylinder didn’t seem like a smart option
