Night Owl
Everything posted by Night Owl
Hello all, after some advice on a concrete lintel replacement. Single skin non loadbearing wall had a cracked concrete lintel above it. Have removed old one and looking for best practice on installing new one. Have installed it smooth side down. Do I bed it on mortar or use slate under the lintel? Thanks
Hello again. Have now had the window replaced on the Dormer so ready to start insulating in that area. Unfortunately trickle vents were added in a location that reduces the thickness of ceiling I can have so made the decision to remove them (Left one already done). Will seal them up with foam or silicon. I intend to install whole house ventilation later so hopefully won't be an issue. Still confused as to the best method for insulating the dormer roof and cheeks. Currently the roof has two layers of green mineral felt torched onto the wooden boards. The side cheeks have a covering of lead onto the wooden boards. As mentioned in the original post, I have 100mm in the roof joists and 50mm in the cheek batons. The maximum I could probably goto now on the ceiling is 170mm including thickness of plasterboard & skim. The maximum on the cheeks is 80mm including plasterboard & skim. Still keen to use sheep wool if I can and would look at putting 150mm in the ceiling (leaving a 20mm air gap) and 50-60mm in the cheeks leaving a 20-30mm air gap. Although they say wool doesn't need a vapour barrier I would look to install an Intello membrane over it to help reduce moisture reacing the timber. I've also considered using phenolic insulating boards as it is supposed to have the best insulating properties where space is limited. My questions are - Do I really need to be leaving an air gap with either method if I install the Intello membrane? Could a combination of both materials be used i.e wool between joists/batons, the cover with phenolic plasterboard? Cost not really an issue for this part of my refurb.
Thanks for the replies. I hadn't considered external insulation but agree it would be the best solution. Unfortunately it will probably be a bit outside my budget and bryond my skillset to make a decent job of it. Will definately be looking to make use of the pro clima intello membrane. Hadn't heard of it before but sounds like a very good idea. One of the reasons sheep wool interested me apart from being a natural product was it's fire retardent properties. Hemp sounds a great material but a bit lacking in this department. There are now companies claiming to sell sheep wool that doesn't have an issue with moth infestation. See link - https://www.sheepwoolinsulation.com/about/ionic-protect/ No idea if this 'ionic' system works to solve the problem with moths. Would fibre sounds interesting too, gain I wasn't aware of the product. So many products and ways to insulate a property these days makes it really confusing. Utimately, I guess any insulation I install will be better than none as is the current situation - providing I don't introduce a condensation / damp problem. That is the key. Looks like I've got more research to do but appreciate listening to what others have found to work for them.
Interested to know how forum members would set about insulating the dormer of my 3 bed late 1950's bungalow? Timber construction as in the picture below with a mineral felt roof covering. I've only got approx. 100mm deep joists on the roof part and 50mm on the cheeks. The rest of the room sits in the roof space (not insulated at present but have probably sheeps wool installed between joists) and is of old 'concrete' block construction. My thoughts were to use sheeps wool throughout but not sure if vapour barriers / air gaps are needed? Also planning to add batons to 'external' walls of dormer room and add sheeps wool there. I like sheeps wool due to it's natural properties and breathability. How would you set about this job? Thanks.
Moved onto the bay window section today. Floor sounded rather hollow in the front part of the bay and started to crumble when hit with a hammer. Totally gone, so dug it all out. The 'cavity' between the main floor slab and inner wall of the bay had been deliberately filled with rubble. A thin slab had been laid over the top. No damp proofing on this part of the floor. The main slab has bitumen however there was some damp between this and the wooden floor - possibly due to a water leak last year. Any suggestions for damp proofing this area and building up the new part of the floor?
Left this wall for a few weeks however it doesn't appear to be drying out as I'd hoped - the cold weather not helping. Decided to continue cleaning out the cavity, it was pretty blocked up! All cleaned up as best I can now for this section. Will brick up the opening now and leave to see if it makes any difference. Should I replace the wall insulation removed behind the bricks I took out? It was the white wooly type stuff that had been installed. Will not replacing it cause a cold spot at the lower section of the wall or will no insulation mean it will be better ventilated?
Hi crispy_wafer, did you ever get BI's take on your notching of the wallplate? Reason I'm asking is that I will need to do something similar to allow some conduit for electrical cables I will be chasing into my walls. Basically need to chase brickwork deep enough to allow conduit to sit in, however it then hits the wooden wallplate at the top of the wall. Ceiling plasterboard is level with base of wallplate.
Hi, thanks for the replies. The property has been in this state for about 8 months now. Had windows open throughout the house every day over the warmer months, but only got the plaster removed over the last three. Lots of draughts throughout due to old windows so there is airflow. May set up a fan in this room to see if it helps. kandgmitchell, the dpc (slate) on the inner leaf is practically level with the bitumen on the floor slab, directly below the brick I've removed. Water could well be tracking under the slab to the edges. Plaster was installed below the dpc/bitumen on the walls which I'm in the process of removing and cleaning out the wall/floor channel. Started stripping out the living room today which has exactly the same problem. I know there is water under the property as I have an old boiler room in a very small 'half' cellar that has filled up by about 3 inches of water over recent months during all the rain. I plan to dry this out later in the year, tank it and fill it in up to floor level. Where the water is coming from is unclear, I know the water table is quite high but to my knowledge, the property has never flooded.
It's been pretty dry for the last three or four days. Not much difference noted inside but suspect it is too cold to properly start drying out. Looked outside today and it is interesting to note that the ground has dried up apart from an inch or so around the base of the wall. I presume ground water must still be finding a way up the wall from the foundations below ground. Been looking at ACO drains and French drains as a possible solution to help with the situation possibly connecting up to a new soakaway. The whole front of the house is concrete though so will be a pain to excavate.
Inside the cavity looking down from DPC (i.e below the slate) it seems to be pretty clear. Although there was a great lump of brick in there Above the slate line a different story. Its only a 50mm cavity and the slate sticks out into the cavity from inner and outer leaves leaving just enough room to fit my fingers through - this is why the fallen mortar hasn't dropped right to the foundations and has built up on the slate Completely clogged above the DPC. I can't put a dehumidifier in the room to try and eliminate the condensation theory as there are so many gaps around windows and only a partial ceiling at the moment. Any input most welcome.
Had another check today to see if things were drying out in the area of the cavity that I cleared. I'm not sure if it has made any difference - possibly the higher damp area has dried post brick removal. Interestingly, the brick dust that was produced when drilling out the lower brick is now very damp where it has been lying infront of the opening - it was dry during drilling. I'm wondering if the damp I'm looking at is being caused by condensation? There is no heating in the property and RH is always above 90% - today it was around 7 degrees and 93%, pretty much the same as outside. Also had a look inside the cavity with a camera and will post a couple of pics shortly. The problem is not just isolated to this area and is in other rooms on both internal and external walls - although only appearing damp in the channel where wall meets floor. How easy can water track along a slate dpc if it manages to get in?
Thanks for the reply. I'm going to leave it for a bit to see if that bit dries however, if the problem is all along the walls then it could be tracking from anywhere. I might have to remove a few more bricks around the room where it's damp at the floor/wall join to see how widespread the problem is.
Thanks ProDave, will definetly do that, it took long enough getting to this stage. I couldn't believe how much mortar was lying behind the bricks. It wasn't loose and took a lot of chipping at awkward angles to get out. Once out though it revealed a nice clear cavity down to foundations and showed up insulation above.
HNY everyone. My damp woes are continuing in my late 1950s bungalow, however I seem to be finally making a little progress and need some advice please. Main bedroom on front of house has a damp issue. I got a damp survey done but all they seem to want to do is a chemical injection and membrane plus replaster etc. Not happy with that so declined the offer (8K quote!!). As I'm refurbishing the property I decided to remove the plaster and have a closer look. Here's what I noticed in one of the particularly damp areas. This is on the front outside wall which is of brick cavity construction. The floor is solid concrete with a bitumin layer then parquet tiles on top. Originally the plaster was put on below the parquet tile level which would have been the cause for a lot of the damp rising up the wall. I've removed all that now. The wall to the right in the picture above is internal however I think the damp may have been tracking from the front of the house along the channel I've now cleaned out. Looking outside, there isn't any leaking drains, standing water, poor mortar joints etc so not sure where it is getting in. Decided to check the cavity so removed a brick right on the damp patch. As suspected, the cavity was blocked with old mortar. Dug it out but found it extended up another brick course, so removed a second brick above which finally revealed some cavity insulation. Dug down a little and found a nice cavity below the slate DPC. Temporarily stuffed it with a plastic bag whilst I cleaned up. Still got mortar stuck between the brick course but will hack that out later. 1. What I would like to know is what you would advise to get it all out along the wall. Would it be best to do a little at a time or support the wall somehow and remove longer runs of bricks at a time? 2. As the problem seems to be across two brick courses, how easy will this be? 3. Would it be better to tackle this job from outside? 4. Would you advise a wall to floor seal or leave it open to breathe? Thanks for any advice in advance.
Looks like the porch is on a bit of a slope. Dug out another hole today at the front of the porch, however it seems to be only half the depth of the one next to house outside wall. I need to look deeper into damp proof membrane and external drainage.
Thanks, will take a look at that. Stuck the hosepipe on the rainwater pipe this afternoon, however no water was noted in the hole I dug. Its possible that the water could be entering on the porch front wall and tracking back to the house wall. For this age of property, how close to the wall is the rainwater soakaway likely to be?
Hello everyone, First post here but have been reading the forum for some time. I am currently renovating our 1950/60s dormer bungalow. Trying to sort out some damp issues at the moment in a front (west facing) bedroom. Initially I found that the floor is solid concrete with a bitumin coating under a wooden parquet floor. I found that when the property was plastered they plastered down below floor level therefore water was being sucked up through the plaster. So, where is the water coming from? I reckon it is coming from outside under a porch extension that was added circa 1980. I get a lot of standing water on the driveway and also there is a rain water drain adjacent which probably goes to a soakaway somewhere. The ground level is very high, you can see the slate DPC barely 1 brick above. Solid concrete with a tarmac covering over a large area. I don't have the funds to reduce the ground level. The porch is much the same with the floor level below DPC! Yesterday I dug an exploritory hole in the porch floor adjacent to the dwonpipe. As you can see, the wall below the DPC was very wet. The floor is solid concrete ontop of balast down to about 220mm. There is no damp proof membrane and no foundation for the porch low brick wall. I shall be doing some more investigation to find out where the water is coming from, however the question I have is how to best relay the floor. In particular, I want to get the damp proof membrane right. I would like to raise the porch floor level a little but will hit problems around the front door as it is virtually at ground level with not much room above to play with. Any advice appreciated. P.S I can't afford to knock porch down and start again which would be the 'money no object' solution! P.P.S Apologies about picture sizing, not very good with IT!!
