goodbyegti
Everything posted by goodbyegti
New extension, brickwork crap? Insulation concerns.
goodbyegti replied to boxrick's topic in Brick & Block
For the wall ties have a read of https://www.labc.co.uk/news/installing-cavity-wall-ties-masonry-walls-0 You don't need to overdo them, just follow the standard. You definately shouldn't be poking then in. You are supposed to lay them on to the mortar. Some people parge coat over the cracks at the end, or you could wet plaster. You will always have some cracks, especially if the thermalites get wet. They shrink as they dry out. You definately don't want any gaps in the insulation. Some people on here recommend EPS beads, which is what I would use if I had my time again. -
I've got about 35m of a1f in Bristol if interested. I used it on my parapet. You can have it for free. Maybe a little donation to Buildhub?
That's a great link Spinny. A must read for anyone building a flat roof.
For the thermal break you can use a marmox thermoblock or similar and then carry on upwards with the blocks when above the roof PIR. You can attach OSB to the blocks for the GRP.
Lime only mortar? (i.e. no cement)
goodbyegti replied to Gibdog's topic in Bricklaying, Blockwork & Mortar
Thanks! It's 125mm cropped Purbeck limestone and a bit of blue lias. Up against some Surecav except the end which is solid. -
We used lime NHL 3 (otterbein), 1 part to 2 parts yellow sand and 1 part grit. It still looks great after a couple of years. It was hard getting a regular bricky to mix it properly. Luckily we found some good masons. You also have to beat it back at just the right time to pack it into the joint. I'd do it again! -
Choosing a roof for a single story extension
goodbyegti replied to JohnyG's topic in House Extensions & Conservatories
^ this, if planning allows! -
That is my understanding of it at least. Perhaps one to agree with building control in advance - you could afterall fit a 200mm packer on the final flight to be removed after sign off. Another random thought: could you add a separate 700mm step on to the 700mm landing? Then it becomes a separate flight. It's tough to visualise with no diagram.
That's correct. You can bond a single ply membrane directly to it. The top layer isn't particularly tough, it's very thin, perhaps 1mm?
I lined it up perfectly in the end..BCO have signed off. Just need to plaster!
The family have gone away for half term, so I decided to move the stairs. I need to extend the joists attached to the trimmer, so that they can be hung off the wall. The trimmer won't be supported at both ends, so I think it has to go. Or I need to seriously beef up the joist it's hung off. So I was wondering if anyone has used splice plates to extend joists? I would be adding them right in the middle, near where the sparky has routed all the cables. The original plan was to replace each entire joist with a full length one, but you guessed it, I need to cut literally every service including almost every wire to the consumer unit if I do that. Perhaps I should get on with it?
Some ideas: - Get rid of OSB between joists and firring strips. As above, you can screw the firings at right angles directly into the joists. - Put the VCL on the top side under the PIR. It's much easier to do a good job. Something like Alutrix will immediately give you a waterproof covering. I think there is a rule of thumb that you can then put 1/3rd of the top deck insulation below the VCL. You could use 100mm sheepswool/rockwool or something. - Will the PIR compress under the force from the pedestals? Perhaps you want another layer of OSB under the membrane? - I think it is costs more, but you can get tapered PIR which could replace your firrings and give you some extra thickness.
How are you earthing it? I did something similar and I had to install an earth rod for the new CU in the shed. I hit some rocks but it wasn't that bad. Took a few goes. I think in many cases you can export the earth from the house, but you need a large section cable, 10mm2 minimum I think. I have the shed running off a 16A RCD in the house (legacy thing), with a 10A RCD protecting the sockets in the shed. It always trips first in the shed, which is good, but I'll be upgrading the SWA at some stage so I can get some more amperage in there.
Thanks both. Tile and a half makes good sense if you could get one. I hadn't thought of that. I think I'll cut the two rafters and get the tiles lined up.
Basically this image from the Facro guide, but two rafters cut instead of one. And everything doubled up, bolted etc. All to get the pantiles aligned like in the pics. If I don't cut the second rafter, I'm about half a pantile out of alignment.
Hopefully a simple one. I have Velux to fit, sized perfectly to fit between the rafters if I cut one in the middle. All very standard. However, the annoying thing is that the clay pantiles don't line up evenly with the flashing. So I am thinking that I should cut two rafters to get the window in exactly the right place. Its either that, or I have to cut the pantiles. Does that seem sensible? I'll be doubling up the rafters on either side and the trimmers.
+1. I made a mess of mine, and brick acid worked a treat. As Mr Punter says, don't skip the PPE.
Just Finished - Thanks for all the Help and Advice !
goodbyegti replied to bob the builder 2's topic in Introduce Yourself
I love the flint work! A stunning effort all round. -
Fitting coping stones to a parapet wall
goodbyegti replied to goodbyegti's topic in General Construction Issues
Both good suggestions. GRP over the top would have given me a problem wrapping over the stone on the other side. I did like the lead on its own, but keen to get a drip channel on the coping to keep the water off the wall. In the end, I had some Resitrix primer left over, and that stuck to the lead nicely. So there's synthetic rubber between the mortar now. Probably overkill! -
I have capped my parapet wall in code 5 lead. Under the lead I have building paper, osb3 and then a cavity tray with weep vents. To finish I have some cast concrete coping stones, which will give a 50mm overhang on both sides, with drip channels. I have GRP on one side, and surecav on the other. I am trying to make it leak proof for many years. Have I missing anything? To fit the coping stones, should I put a layer of bitumen paint, or silicone a DPC on? The main reason would be to prevent the cement reacting with the lead. But I was also thinking about thermal movement of the lead which the DPC could perhaps help with. For the mortar, would you go for a 3:1 mix as per NHBC guidelines? Is it worth putting fibres in, or some mesh?
