@Kelvin and @Thorfun where did you get your panels from? I've been working of a sheet of MDF with DIN rails mounted but I need to start getting to a point of completion and cabling everything in with a door. Thanks!
I've had a peak - you're finding your way, as am I 🙂
Yes, the terminal blocks. I get the concept, but I don't see the why the double and triple decker versions?
Couldn't these be used for all the different circuits, whether it be from a dimmer extension or just using the miniserver relays?
Sorry, another thing - just to make sure I'm not missing something.
What's the point in the Weidermueller double and triple decker terminal connectors? Or is this only really more suited to retro fitting where the switched twin and earth is being run back to Node 0? I.e. netural with a brown sleeve over wired back from the original in-wall switch or light fitting?
Thanks again.
Hello everyone! 🙂
I've been having a quick ready through this huge thread...at the moment I have one question.
-Why are the Weidermueller terminal connections so expensive and where are you getting them from!? Loxone actually seems to be the cheapest place (each).
Also, funny photo, but she doesn't look happy.
Thanks in advance, Tim
Hi there, old post I know... in 2024 is there anywhere or any other manufacturers that provide a busbar and compatible isolator and RCBOs? It's a neat solution to save on mounting a seperate terminal. thanks.
