Alshamal
Everything posted by Alshamal
When panels and inverter are added how are they connected to my existing system to charge the batteries /grid etc does it have to communicate with the existing inverter to charge batteries ? And how do you use it to charge the ev? all questions i know 🙏
No it’s not a hybrid one !
I had Lux 3.6 ACS Inverter with 9.6 Greenlinx batteries fitted 4 months ago and I’m pleased with them financially and just left to charge on cheap tariff Octopus GO I also have an EO charger for my EV. I’m now looking to add solar and not really technicaly minded so any suggestions and help would be greatly appreciated in this minefield! Had a quote starting at 12k reduced to 9k on first refusal so told them to go away. I’ve just had a quote from OTOVO for 9x415 Trina panels and Growat mini hybrid inverter etc fully fitted with 7 years warranty fro £5,530.00 But when I asked for them to take a deposit with credit card! They said only pay balance when completed with bank transfer! Had a local firm 7x425 Trina panels 1 Solax -3t fully fitted £5,614.00 but would take any payment method for deposit. what’s your experience and thoughts would greatly appreciate your help
Hi Nick Thomas How did you find out the prices of the Lux Inverters? And is there only one retailer in the country. I’m getting no reply from Home Energy Group on help !
Just had a conversation with an installer who only uses micro inverters! Apparently this cuts out my inverter issue but this means the same amount fo inverters as panels! But wanting to know how I would charge batteries and EV, he also proposed 10 panels as say 5 on the south and 5 on the west.
I have a battery system charging on Octopus Go and charging my EV on the cheap tariff overnight! How would a panels system using micro inverters connect as they will be supplying AC current ! I’m new to this🤷 thanks for all help
What’s the benefits of using Micro Inverters just been told they are better and the way to go! But are they more expensive one for each panel!
They supplied and fitted mine but I think i can honestly say it’s my fault for not knowing enough about what I wanted and may need in the future! The difference in price would make it worth upgrading at a reasonable cost in comparison to paying a grand plus with panels! I spoke with them this afternoon and pleaded ignorance and everything else,so may be lucky 🤞just have to wait and see. I’m just starting the process of P V every thing seems to be worked out from Google earth!
Hi Nick Thomas Thanks for your reply I thought when i had the inverter/batteries fitted i was led to believe the inverter would do all I needed if and when i went for solar! It explains when asking to supplier for information on solar they’ve never replied! I’m only 3 months down the line since finding out! What is the difference in price of the inverter i have to the hybrid one I can’t seem to find any pricing for just Lux inverters ! If I went back cap in hand and pleaded ignorance which isn’t far off! and see if they would exchange it? or just accept it and pay for an extra inverter! 🤷
Hi Redbeard thanks 🙏👨🦳 i am looking to fit panels👍
I’m on Octopus Go 7.5/38.5. I have an EV and charger!
I’ve got a Lux 3600 ACS Inverter with 3x 3.2 Greenlinx batteries system fitted 13/10/22 which I’m well pleased with supplying 98% of my daily use! My last years electricity usage was approximately 6,000.KWH. So I’m not looking to fit solar panels on south facing semi bungalow roof! i’ve had a quotation for fully fitted all certificates using existing inverter. 6xJinko Panels 415 (2.4) kWp @ £ 4,397.00. & 9 Jinko Panels 415 (3.7)kWp @ £5,022.00.
Where’s the best place to look for prices and sizes etc thanks for all your positive responses and suggestions a breath of fresh air 👍 Happy Christmas and a happy new year 🎅🏻
Just rethinking what Nikfromwales says those conditions only applies if sited on the ground! I’m thinking of doing the same as the photo of the car port but on my gazebo which is on the boundary! As the photo attached.
The Gazebo is on the boundary 🤷not possible for me then😡
Hi Nickfromwales That looks just what I’m thinking of doing not sure what size those panels are! Are they all a standard size? That roof doesn’t look 10 mtrs long.I just want to top up the batteries I wouldn’t need any certificates would I? Just need a Sparky to connect them to the inverter. I could fix them to the roof.
Hi Dave C How do you get the once a month extra hour on the Go tariff?
Hi ed g it charges the batteries and my E V on the 4 hour cheap tariff 00.30-04.30 once it was set up it that’s it don’t need to do anything,It provides the majority of the supply except when the electric fan oven is on! Then the grid tops up! I went with the Greenlux batteries advised by H E G and they provided a double socket on a long cable EPS .i got a very good price for the installation! Give them a ring good to deal with and good support which I thought was important! I have a gazebo close to the house with a flat roof approximately 2.8 mtrs x 6 mtrs facing due south with no shade. Is this size any good or worth fixing solar on ? What is the lowest degree they can be fixed?
I had my 9.6 kWh Lux 3600 AC Battery System fitted 13/10/22 I’m on Octopus Go with an EV the system comes with 10 years guarantee extendable to 20 years for an extra £450.00 not sure I would benefit from this as all my future is behind me at 75👨🦳 But so far so good saving approximately £2.46p per day!
I have a 60s brick/concrete roof tiled semi 2 bed hipped bungalow, it’s got basic insulation in the loft between the ceiling joists 3”x2” then when i had the cavity wall insulation done they put another layer of insulation across the top of existing approximately 125mm. what’s the recommendation to increase the depth to? If any or is what I’ve got is good enough! If more required any advice on best value and best to use. I’m a pensioner so would have to get someone in to do it! Thanks in advance for any advice and suggestions.
Had a Lux 9.6 KWh system installed just over a month ago and getting to understand it and making the best of my Go tariff. Was just interested what other more experienced people than me have found the most economical use of the battery power to heat a room? Oil filed radiator/ convection/fan heaters! we have gas central heating we use in the most used area of our bungalow but have a TV room which i have to use to watch my Sports 🤷
