JackofAll
Personal Information
  • Location
    the edge of the bog
4394 profile views
JackofAll's Achievements
Regular Member
Regular Member (4/5)
20
  1. Depending on size on patio, you could throw down broken glass(smash up alot of bottles) under the pedestals/pavers. Rats won't bother with it. Go to local pub or often times bottle banks are full and people just leave bottles beside em, and it's free.
  2. The seals on ours are the same any thankfully no waviness either.
  3. @Mr PunterNo issues regarding leaks, it just doesn't look right. @craig can't see anything that would cause the seal to be pinched, will look into adjustment. I know every openings vary, is there a normal distance between the pin and the locking keep that you've noticed?
  4. Hi all, Anyone with internorm windows notice the seals appear to have pinch marks on them like below grey seal.
  5. It's approx 12m, the job ain't finished so the Soil pipe is just sitting on the AJ.
  6. So the soil pipe is higher than the inlet on the AJ(see pic). Was thinking of cutting hole in riser and sliding onto pipe but due to the moulding of AJ there are three flat spots with the bigger one obscured by the pipe. Would be afraid of waste falling and sticking on this. There is a 1/60 fall on soil pipe am afraid by fitting a bend further up soil pipe and connecting in at the inlet on the AJ that the water may leave the waste behind. Pipe run is right to left. Any ideas?
  7. Thanks Nod, few tilers looked at it and said that i would need to get the heating up and running (which it now is) 1 deg a day for a few weeks and allow to cool for a week before tiling could commence, it's now set at 30 degrees and tbh will never be set that high again(21, maybe 22 if she gets her way). Floor is down since July 23. so it will be no harm to do the same thing again once the tiles are down, thanks again.
  8. Hi, Starting @ 20deg temp (lowest setting)what's the max I need to hit to see if any cracks appear before shutting off to allow cool and tiling prep can start? Bear in mind it's 6 inches of concrete.
  9. Water heated via ASHP, will get a reducing valve to be safe, thanks.
  10. What purpose does the pressure reducing valve have? Will try the bucket tomorrow, thanks.
  11. Checked tap(albeit a make shift one) at full bore that was reading 3.9bar though that was the middle of the day, will try it morning and evening too. Is it OK to plumb toilets handbasin etc direct from main?
  12. Is a water storage tank essential, currently connected to mains and hope to drill a well before the year is out. Had initially planned for pumped tank in plant room but after checking the water pressure (3.9bar) just wondering if the tank is now needed. I know if the mains were disconnected you would have the storage tank bit that wouldn't last pissin time in our house. Any ideas?
  13. The top layer of steel looks awfully close to the surface compared to ours
  14. JackofAll
    Diy raft
