ahdinko
Everything posted by ahdinko
  1. They sound like pretty good risk mitigations. Just make sure you aren't downgrading security elsewhere to make stuff work with the XP machine (such as turning on SMBv1 on your newer machines to make the file sharing backwards compatible with XP)!
  2. Look at Shielded cable instead of UTP, it has a foil shielding layer to help cut out EMI. I've seen very rare but weird things happen from cable interface though. Had one with network degradation when one circut pulled alot of power. Took a long time to diagnose that one!
  3. XP is insecure, unless it is totally isolated from the network, the likely issue is something you get on your Windows 10 machines may not be able to execute properly, but if it can copy itself from there over to the XP machine where it can execute using an unpatched vulnerability and then spread from there.
