WisteriaMews
Personal Information
Location
England
WisteriaMews's Achievements
Member (3/5)
16
Someone I follow built this tool to calculate the best Octopus tariff to be on. If you plug in how much you generate, how much you.use etc.... it will tell you the best tariff. Solar Tariff Optimiser https://share.google/j6ENJD1G8wSMKYbLl
Raft foundation - close to existing structures
WisteriaMews replied to WisteriaMews's topic in Foundations
Thanks. This is the type of experience from people who have done it I was hoping for 🙂 -
We're currently at the planning stage so don't have a foundation designer / structural engineer on board yet. I appreciate these will be the people that need to give a definitive answer but I was wondering if anyone on the forum and done similar and could share their experience. -
Does anyone know with a raft foundation how close you can get to existing structures? We have an existing sewer connection on our site with a manhole that drops about 4m and then runs to the boundary and main sewer. The constraints of the site mean we will need to get as close to it as we can. (The quotes for moving the sewer connection have been high.) Separately we have a brick boundary wall that will be the rain screen for the ground floor of our build. To avoid the expense of a demolish and rebuild could the raft get close enough to avoid this? Grateful for anyone's experience!
PCC / Warranty recommendations
WisteriaMews replied to PhilC's topic in New House & Structural Warranties
Depending on the reason you're getting a warranty it might be worth looking at ones that are widely accepted by the major lenders. For our build I made sure that I got one which was widely accepted so I'd have no problems getting a mortgage (or if we needed to sell, the person who we were buying from wouldn't either). Lenders' Handbook - UK Finance Mortgage Lenders' Handbook https://share.google/jARd4XhwAN9ElprPc -
Comparing solar/battery ecosystems
WisteriaMews replied to lookseehear's topic in Photovoltaics (PV)
When selecting our system I wanted the option to be able to use it with smart tariffs. Octopus seems to be the leader in this space so I checked which systems they are compatible with. We're a way of installing but I've specified a GivEnergy battery on this basis currently. -
Structural Engineer: Build Collective, Bristol
WisteriaMews replied to WisteriaMews's topic in Surveyors & Architects
Based on Companies House data I think Build Collective are now in administration, hopefully no one has been caught up in the situation. (We ended our relationship with Build Collective not long after I made the original post.) -
We're a bit complicated with a timber frame sitting on a basement. Our basement design has ended up a certain way through working with the structural engineer and a contractor to keep the cost down. MBC have their timber frame design and the way it transfers the load through the frame wouldn't work with our basement design per their standard details. They didn't seem interested in doing things differently and I didn't want to work so badly with MBC to try convince their structural team we could find a solution.
We have a timber frame company hopefully lined up (MBC weren't interested due to our foundation design). We're searching for a follow on contractor that will know how to install windows to a passive standard, wont puncture lots of holes in the air tightness layer and just generally buy into the concept of what we're doing.
Does anyone have any recommendations for passive house experienced builders that operate in south east London? We are hoping to issue our tender soon for the house we're aiming to build to a certified passive house standard. We'd ideally like a contractor experienced in the passive house approach so they are across all of the necessary airtightness and thermal bridging requirements etc.... I've looked on the Passive House trust and AECB websites, but south east London seems to be a bit of a desert for registered contractors! We have spoken to one contractor who has sent someone on the PH contractors training course, but they have never done a passive house project.
Cavity barrier and wood fibre insulation
WisteriaMews replied to WisteriaMews's topic in Timber Frame
Just in case others stumble across this thread with the same question, I've been told by one of the wood fibre technical teams that there is some compliance testing taking place in September 2025. -
We've been quoted a very similar price.
Not installed yet, but we're planning to use GSE trays to make the panels more or less flush with the standing seam The solar company have said there is no extra cost of the GSE trays vs clamps and rails to put the panels on top of the standing seam. We haven't finalised the tinsmith yet. We've spoken to one who has said they've worked with the GSE trays before so we know it's all doable. In theory a saving as there will be no standing seam under the panels. The tinsmith will have all of the flashing details to do around the GSE trays though. (I find somehow things are never cheaper!)
