Afternoon everyone,
I have been dipping into the BuildHub Forums for quite a while and found it a great resource. Now though I think I am at the point in our build to ask for some direct opinions and ideas.
Briefly:
We are building a new home based around a class Q barn conversion. Currently we are up to DPC and having to make some decisions which I could do with some help with.
My main consideration at this point is heating. We will in all likelihood be Off-Grid for electricity purposes relying on a very large PV, batteries and back up generator, possibly a wind turbine if I can find a reasonably sized and cost effective option.
The result of this decision is that we can not rely solely on electricity for heating purposes. We do intend to fit a GSHP or ASHP (I have been around and around in forums on the merits of GSHP vs ASHP and believe I have settled for ASHP) to utilise the electricity generated from PV if the batteries are full. We will have to rely on more 'traditional' heating methods during the winter. Whether that be oil or gas. However we have also planned to install a wood burner and I thought it may merit being a boiler stove so we can dump the heat generated into a store to be used more purposefully in DWH and the UFH - this will mean installing a Thermalstore rather than a UVC.
My question is:
Is it worth bothering with a wood stove boiler and the thermal store?
My plumber has advised that the wood stove will burn less cleanly until the return temperature is up to about 40 °C (however I don't see this being a massive problem since the store should never be starting from cold unless we have completely run out of alternative sources)
Thermalstore vs UVC, seems to be a lot of opinions on this. Simplicity vs efficiency - common conception is that the thermalstore will leak more heat than a UVC - (recommendations on the highest insulated and performing ones welcome)
Safety - Wood stove will need a pump to return the heated water - if this fails we don't want superheated water spraying over us.
For all the aforementioned considerations, even if overcome or positive, to save a few £100 a year on heating oil or gas are we overcomplicating the system when a UVC connected to a oil/gas boiler and ASHP will suffice?
I should mention that our objective is not going to be shovelling wood into the stove all day to offset the use of oil/gas. We will light it when it is cold/coldish/ and we want the atmosphere of a fire. I have been told by many overheating with a wood burner is likely to be our biggest worry, hence another reason to fit the stove boiler so the majority of the heat is absorbed into the water rather than towards the room.
Any thoughts and opinions very welcome,
Thank you
Chris
