harry_angel's Achievements
Regular Member (4/5)
20
Is this a good price for oil installation?
harry_angel replied to harry_angel's topic in Boilers & Hot Water Tanks
Hi Ian! From all I've read though - how can millions of off gas grid properties be expected to do this? It's financially impossible for everyone to switch. See my comment just now about ASHP concerns / issues for us (and also that this building is not classed as a new build). It's definitely not a clear and confident solution for us. All very difficult this!- 13 replies
- oil boiler
- oil tank
We are at first fix electrics stage - with heating and plumbing first fix to go in next. Two crucial things - 1) It won't be classed officially as a new build because it is an additional building on our plot "ancillary to the main dwelling house" so no money off / grants available to us here... 2) We have screeded the floor already so the moment for under floor heating has gone. Although we could lay it on top potentially, in theory, the French doors and some other door / window furniture would not allow for this re: measurements. From an ASHP perspective, we were also warned that not enough heat, and definitely not enough hot water, would be delivered if - for example - we had four people staying in there and they all wanted a shower in the morning. If we're letting guests stay there, we can't be dealing with complaints about lack of heat and hot water over and over. This is why a hybrid version, if possible, may be the ticket - if the boiler tops up where the ASHP can't stump up...?- 13 replies
- oil boiler
- oil tank
Thanks. We looked at the LPG route and had the plans all drawn up for tank etc but the providers won't deliver the canisters to us due to access (which is ridiculous) so had to scrap that idea. We also looked at connecting the the gas mains. But just for them to put an external pipe in and connect it up (not including digging the trench and preparing the ground or the boiler and plumber's work internally) is £25k+ so that obviously put us off... I'm not sure for this build ASHP is going to work well enough on its own. But I will certainly look into the hybrid option you suggest with oil. Cheers- 13 replies
- oil boiler
- oil tank
We have a new building which is quite isolated and getting on mains gas is going to be prohibitively expensive. So we are taking the view to over-invest in insulated plasterboard and go with the oil tank and boiler. But is the below a decent price? SUPPLY AND FIT NEW GRANT EXTERNAL COMBINATION BOILER. SUPPLY AND FIT PLUME DEFLECTION KIT. SUPPLY AND FIT ALL PIPEWORK AND FITTINGS NECESSARY FOR CENTRAL HEATING INSTALLATION. SUPPLY AND FIT NEW GRANT MAGNETIC FILTER. SUPPLY AND FIT ALL RADIATORS AND RADIATOR VALVES AS NECESSARY. SUPPLY AND FIT NEW BUNDED OIL TANK 1800L. SUPPLY AND FIT NEW BASE FOR TANK. SUPPLY AND FIT FIRE SAFETY VALVE. SUPPLY AND FIT TIGER LOOP, AIR FILTRATION. SUPPLY AND FIT OIL LINE FROM TANK TO BOILER. SUPPLY AND FIT PROTECTION BOLLARDS FOR OIL TANK. CARRY OUT FULL COMMISSIONING OF CENTRAL HEATING SYSTEM TO INCLUDE DOSING WITH CHEMICAL INHIBITOR. AS A G1 INSTALLER CUSTOMER WILL RECEIVE EXTENDED WARRANTY ON BOILER. TOTAL: £14,900
- 13 replies
- oil boiler
- oil tank
Do I *have* to allow a planning officer access?
harry_angel replied to harry_angel's topic in Planning Permission
Sorry for delay, they didn't even request access in the end! -
Cheers @IanR aka "The Guru". Will get boarding shortly. There are no stairs, there is nothing up there, a 1st floor appears nowhere on the plans submitted. @redtop nope, internal walls not plastered yet. -
No it's nothing sinister, approval is already secured we just made some minor changes in the construction process. It's simply that the "upstairs" (there are no stairs, so unless the officer can levitate she'll struggle to get up there) is just a void, non-habitable. But I do not trust my LPA and do not want them even attempting to use floor area against me... -
We have a pending S73 app (hopefully the last), which has (now) been built to the previously approved building shape/dimensions etc. Or, in other words, re the exterior there is: "nothing to see here". Of course, internal changes which do not affect the external look of a building do not require PP. Therefore, if the planning officer* inspects the site do I - by law - have to let her see inside it if she requests? It's locked currently. I guess this centres on whether a planning officer HAS to assess simply what is being shown in the drawings, and what they were able to see in their site visit (if they do one at all). *note I am referring here specifically to planning officers, not enforcement officers.
@Bitpipe LOVE brokers at the creative/problem-solving end of the market! Yes pls do pm, many thanks
- 31 replies
- equity release
- second charge
(and 2 more)
@Ferdinand no, I'd be able to bootstrap finance it myself faster out of work cashflow. The problem with that route is twofold though: 1) slow and 2) will leave us a little light in rainy day money. @Dave Jones sure is tempting to get rid, but if I did the next guy in is going to light it up....on the back of my hard graft. Better to fight through it. @pocster and @Bitpipe yes we have a decent one but I am conscious the game moves fast and also even the best brokers have an element of autopilot to them. @Bitpipe that is an absolute tale of woe and no mistake. Good for you getting through it.
- 31 replies
- equity release
- second charge
(and 2 more)
@ProDave see bullet 2 in original post. @Zak S thanks for the insight. Your 2019 situation sounds stressful indeed. I find it slightly insane, I guess, that in this supposedly evolved time we live in that one would have to go back to the "old ways" of passing a hat around family and friends. On that note we have already had some help from a friend, who is now almost repaid (2 payments to go). But re your earlier point the exit strategy is essentially: hang on to legal ownership of the property until such time as the acreage it sits in is develop-able (a matter of time, albeit quite a long time, is the professional view). In the meantime however we're stuck in this financial bottleneck where we are having to bootstrap necessary refurbishments (the house has soared in value due to the demand for land pre/post covid, but will go a lot further still) out of earnings, which means everything moves at a glacial pace. Depressingly this is looking more and more like the full-time job of kissing investor frogs until one takes pity on us OR doing a little bit here, a little bit there, by which time they'll probably lower us into the ground just at the precise moment everything's finished.
- 31 replies
- equity release
- second charge
(and 2 more)
This is interesting re equitable charge loans > https://www.taptoncapital.co.uk/equitable-charge-loans
- 31 replies
- equity release
- second charge
(and 2 more)
@Mr Punter sounds like a swell deal. What multiple on earnings did you secure? Did you go for interest only? @matthyde83 interesting, thanks, yes had heard of Habito. We have 1.5 years left on the current mortgage, but I really need the £100k+ prior to that. Researching the interest-only route in order to increase affordability, and looking into private mortgages and equitable charges this week....
- 31 replies
- equity release
- second charge
(and 2 more)
@Mr Punter been with the lender 6 years, not missed a payment or a deadline. Happy to be proved wrong but my experience is contrary: two self-employed people? Providers are Not. A. Fan. And the mortgage, while affordable, is undeniably big. One option would be to find an interest-only lender though, as then the stress test might be much easier to pass.
- 31 replies
- equity release
- second charge
(and 2 more)
@SimonD I guess my nervousness around going to the lender is once you've done that, if you then later choose to do something a little creative a la the equitable charge then the account might be flagged or something. I tend to fly very low with the main lender, pay them on time, every time and leave them well alone. I am very interested in the equitable charge via a HNW though, so thanks for that idea and will start digging into that in earnest tomorrow. @Mr Punter alas remortgage via another lender is out due to bullet 2 above, our earning wouldn't pass the stress tests currently as my partner's situation has changed. @Ferdinand my partner has a pension but I don't. I think it's a super-restrictive one, though, so that getting a loan against it is tough. Personal loans we are already tapped out on - we're paying them back each month standing on our heads but I think the algorithm has kicked in now and the only personal loans we're being offered are these awful credit builder credit cards for £3k! Determined to crack this: was looking at the valuation letter earlier (not Foxtons I should add!) and it's absolutely bonkers we can't get at a measly 10% of what's there!
- 31 replies
- equity release
- second charge
(and 2 more)
