Dillsue
    1
Dillsue last won the day on June 22 2022
Dillsue had the most liked content!
Dillsue's Achievements
Advanced Member
Advanced Member (5/5)
423
  1. More EVs equal more industry turnover so maybe the current cheap rates are a loss leader??
  2. The EV charger is integrated with a solaredge inverter which Predbat doesn't seem to list as compatible. The solis is just for the battery. Even if I could automate the charger, I'm not sure agile would work for us as the only time the car is routinely plugged in is during the night which when I looked recently at agile rates seemed to be significantly more than the Go or EDF overnight rates.
  3. The EV is the problem we have with agile as our charger isn't smart so we could end up charging at more expensive times. The wife isn't going to be tracking agile prices to know when to plug the car in! A mate is using Sigenergy AI in tandem with agile in and out and reckons he's making £70/month. Not sure how good eleccy trading is for battery longevity?? Until I realised that AI and agile weren't compatible with our EV charger I looked at the Solis AI tool and that factored in battery degradation cost in deciding whether to carry out a charge/discharge trade.
  4. I keep seeing ads for EDF advertising 7 hours off peak eleccy for 6.66p/unit on an EV tariff. Anyone know if that rate is a new deal or been around for a bit?? Octopus have just hiked our 5 hour off peak Go rate to 9.4p/unit and EDF offer a penny a unit more for export so a move seems an obvious thing to do?
  5. Won't cheaper prices mean more consumption requiring more levies/taxes to build more wind turbines, solar farms, nuclear plants, battery banks, CCGT+CCS etc??
  6. You don't need to be a geek to install and set up a HP- it's basic physics. HPs are proven technology over a century old. The trouble with the plumbing/building industry is there's no incentive to change. Your builders advice was flawed as changing things he's always done comes with risk to him so he advises wrongly to hopefully avoid a perceived risk. If the plumbers your builder uses had embraced HPs with training and experience, the builders perception and advice would likely be different. Unfortunately there's incentive for those plumbers to change.
  7. I understand all of what you say but I'm trying to understand why there's a mismatch between the Axle event looking for grid support and the apparent lack of a need for grid support by Octopus. If the grid needed supporting from 7-8 then I'd have thought Octopus would have been pricing to gain that support from their customers such as my mate who had spare battery capacity but didn't export because Octopus didn't price to encourage him to. I appreciate Axle aren't new to this but I'm trying to understand if their seemingly illogical actions are due to them getting support for trialling this concept??
  8. Just to add last night's event went off seamlessly with the Solis inverter reverting back to normal straight after the event.
  9. Given last night's event was out of the normal peak period of 4-7 pm, It's hard to understand(for me) how they can bid such high prices in a competitive market unless they are getting some sort of subsidy to be operating on a trial basis?? We're the guinea pigs for the trial and being paid to help out??
  10. I checked with a local mate who's on Agile outgoing and in the area covered by Axles map and his rate peaks an hour earlier than Axles event. Seems odd to me. I guess it could be a test to see the export response they get with lesser influence from those exporting in time with export TOU peak prices?
  11. Just had a look at the local Octopus agile outgoing rates and their evening peak seems to be an hour earlier than Axles event. Anyone know why the Axle event and Octopuses outgoing peak don't align??
  12. Just rolled in to an email from Axle saying our first event is on tomorrow 7-8 pm. Just upped the max SOC to 100% so hopefully there'll be enough juice for them to take the max they can
  13. Assuming the HP came with a new build 2 years ago then it will likely have a controller or app that will display COP or SCOP. Have a look at the user manual and find the COP/SCOP. Once you've found that value look up the HPs data sheet and compare your value to the values in the data sheet. If you've got a value near the top of the range(higher value is better) then you're doing OK and you'll have to teach yourself alot to improve things for what may only ever be a small gain/saving. If youre lower down the range then the gains/savings may be greater and worth your while reading up on HP efficiency so you can assess your system and make changes. Finding out your COP/SCOP is the first step.
  14. Have a read of the FIT guidance for generators so you get your set up correct. Adding an AC coupled battery between the generation meter and your consumer unit/incoming supply is likely acceptable. The guidance will also tell you if the change has to be notified to your FIt payer, which lots of things do have to be notified. If your FIL already has a 4kw system he'll need to get consent from his DNO to add any more potential export such as a battery. Don't be put off by the red tape as its all straight forward once you understand the constraints.......no one want to loose early FIT payments:)
  15. What the installer feels is appropriate should be based on what you told them you want......did you get what you wanted originally and your lifestyle has changed that you need/want to change things 2 years down the road??
