  • entries
    20
  • comments
    87
  • views
    6780
The start of the renovation story.
TheMitchells
As some of you may know, we have been looking to build for several years but are finding it very hard to get a plot near here within our price range.  We have been waiting for Graven Hill since early 2013 but after more than half a dozen deadlines came and went, with never an explanation or apology, I wouldn't touch the plots with a barge pole now.  But I don't want to get too disillusioned so while we wait to find the 'ideal' plot, we were offered the chance to buy a nearby small rundown Victorian end terrace for a very reasonable price.  It looks just right as there isn't much structural stuff to be done so we hope to be able to do most of it ourselves.  The OH retires in November so I have to have something to keep him busy.
I have attached the building survey and here is the front of the house.P1090635.JPG
It's a bit of a strange location as our row of 7 cottages are set behind a row of another houses which are on the main road.  We have to walk down a narrow alley behind the other row, to get to the front of ours.  Its about 60m from the road and there is no way of getting a vehicle any closer.  Initially this did put us off; however, it is clear that people manage quite well. Most of the houses have had extensions built so it is possible to do most jobs but extra time and effort will be needed to remove and get things to site.  Skips can be put onto the road and everything will have to be wheel barrowed onto site; so not the easiest location for a fairly major renovation.
As you can see there is a small alley between ours and the house on the left. That takes us to the rear of the properties where we have a narrow path behind the house, leading to the back of the house to the right, to their back door.  There is no back garden, just a wall (which is leaning quite badly) then a raised garden belonging to a house on another road, which runs the whole length of the row of cottages.  It is quite strange as the chap can be gardening while looking straight into the kitchen window.  Not ideal I know.  However, he is old and there is talk of all the cottages buying the land to the back, which we have said we'd be happy to do too.  But I don't think it will be very straight forward to waiting to see about that.  The wall belongs to this chap too and he knows it is leaning and needs work so I am hoping that will give him an incentive to sell.
There is room to get alongside the back, that's our lovely wooden back door, leading to the yellow house/extention of the neighbour.  The house in the distance behind the huge holly, is the owner of the gardens.  Its a long, long garden.
So, about the house.  We believe it was built around the mid 1800's, as church cottages to the nearby church building, dated 1836. We are the end of three with a row of four next to us.  The front of the house faces south so the garden gets plenty of light.  On the ground floor is a front room, stairs, a bathroom, middle room with the kitchen in a newish extension at the back. Upstairs there are three bedrooms, one large at the back with two smaller ones at the front.  I plan to create a post for each room with lots of photographs and what we think we need to do for each room.  And to add plenty of excitement - we have a cellar - an old fashioned coal cellar the full size of the house.
It's a bit rickety and the bottom step is missing.  There are Akro props holding up some of the beams under the front room and the surveyor says we need to replace them all.  Unfortunately there is not sufficient height to stand upright although I can manage it with my head between the beams.
That's the coal store and the board to the left was the shaft which went up to the front garden, under the front window.  The previous owners had it blocked up and the front wall waterproofed down to cellar level, rendered and painted.  No mention of insulation in the document.  What to do with the cellar is one of the many questions we are looking at.
The idea is to renovate with the intention of selling and hopefully making a profit or, if the economic situation is not favourable, then we can rent it out.  But this will be a slow renovation and we have no intention of being in by Christmas and I certainly have no intention of getting pregnant!  We are using it as a learning experience as this is far more than we have done in the past.  We have a builder lined up for some of the work but the rest we plan to do ourselves.
I am sure there will be lots of questions for our fellow buildhubbers in the months ahead and I hope you enjoy reading about our progress.  Advice and tips always welcome.
Building Survey Report Blank.pdf
  • Like 1
3 Comments
Recommended Comments
If you have to replace the floor joists, is there any merit in using steel? You can get the strength you need in a much smaller thickness.
A nearby pub is doing this where they need to lower the floor level of a bar they are renovating to enable wheelchair access. Lowering it and keeping wooden joists would result in insufficient headroom in the cellar. So instead they are installing a set of steel floor joists that lower the floor level while still keeping enough headroom in the cellar.
I take it the second picture shows a single storey rear extension to your house that takes up all but 6" of your back garden?
  • Like 2
Yes, it does look like 6 inches but its actually about 2 foot and if the wall was back where it should be, it would be about 3 ft (thats 90cm for the youngsters reading this).
We will consider steel but there is the issue of access - I thought wood would be lighter and cheaper.  although steel could be brought in in sections and bolted together.  Will have a good think about that as we had not considered it to help with head height.  Will get a post done today about the cellar and put more photo's in.
Here is a plan of the ground floor to give an idea of what is where.
And a map of the local area to show where the house is in relation to the road.  You can see the alley to the right of the church, which then runs along the back of the houses in the road.  Ours is marked in red. land registry map of house.jpg
Edited by TheMitchells
