pritch Posted June 2, 2019 Share Posted June 2, 2019 Hi Last time I put steel reinforced mesh on top off the insulation and tie wrapped my pipes to it to hold in position . It worked a treat and the weight kept the insulation flat and made it better to walk on while screeding etc. That was 15 years ago. Is there anything better out nowadays or is this still an acceptable method? Thanks Link to comment Share on other sites More sharing options...
Jeremy Harris Posted June 2, 2019 Share Posted June 2, 2019 That's exactly how ours was laid: 1 Link to comment Share on other sites More sharing options...
PeterW Posted June 2, 2019 Share Posted June 2, 2019 20 minutes ago, pritch said: Hi Last time I put steel reinforced mesh on top off the insulation and tie wrapped my pipes to it to hold in position . It worked a treat and the weight kept the insulation flat and made it better to walk on while screeding etc. That was 15 years ago. Is there anything better out nowadays or is this still an acceptable method? Thanks You may have got away previously with using lumps of paving slab as chairs for the mesh - you’ll probably be asked to use purpose made chairs now, however the triangular long lengths are a piece of cake to use now anyway. Link to comment Share on other sites More sharing options...
