Odannyboy Posted April 18, 2019 Posted April 18, 2019 Hi all, i am just looking for some advice on the basics regarding planning permission. I have just purchased a property and am looking to add an extension to the side of the property and wondered what size I can erect without getting PP? thanks Dan
newhome Posted April 18, 2019 Posted April 18, 2019 Welcome. First of all you need to check whether the property has had its permitted development rights removed or restricted or not. If not you can build certain things without needing PP but you will still need to go through Building Control if building an extension. The other complication is that current permitted development regs expire in May 2019 and it's not clear whether they will just be extended or amended afaik. It depends where you are too. Here is the portal for England. Permitted Development Portal - England 1
