Jeremy Harris Posted May 5, 2020 Posted May 5, 2020 Definitely protect the cables, as the PVC insulation will go very brittle if it's touching EPS. Non-PVC tape would do at a pinch, but better to just use a bit of flexible conduit over those bits. You can get split flexible conduit that can be fitted around cables that are already in place that might fix those areas. 1
