I recall the PVC sheath of electrical cables and EPS should not come into contact, is there any issue with MLCP pipe work contacting EPS? I have a small sub-floor void where my UFH manifold presents and would like to fill it with EPS beads, is there any concern with a reaction between polystyrene and the (I think) polyethylene pipework? I could wrap the pipes in a cloth tape prior but it will be a faff and would rather not bother..
No, it's fine.  The problem is only with the plasticisers in PVC cable sheathing, and polyethylene, or any other plastic that doesn't use plasticisers to make it soft and pliable, will be fine.
