Alex C Posted July 29, 2016 Posted July 29, 2016 The NHBC guidelines are for minimum 25mm sound insulating material and 25mm plasterboard. I would be using this as a minimum in my own house. You could use 2 sheets sound block plasterboard. You need to make sure that the svp does not touch any timber as this will transfer sound as well. a 127 stud is no way big enough, you could batten over it to give some extra thickness.
Mr Blobby Posted March 22, 2022 Posted March 22, 2022 Just to resurrect this old thread, do acoustic soil pipes like Marley Blue actually work? And by work, I mean can I get away with a smaller box around the pipe with similar noise suppresion as a big box and rockwool? Or maybe just put the pipe outside, it is on a hidden part of the house.
