As-built SAP
m4tth3wb
It's almost time for the final inspection of our build and I would just like to know what happens regarding the as-built SAP report?
Do I get a form to fill in from someone?
Is it me who fills in the form or our inspector?
Does someone come out and check everything is as we said?
Cheers
Matt
No one checks anything at all, it is entirely based on the information you provide.
You just give a registered SAP assessor the as-built information, he/she produces the as-built SAP, lodges the EPC on the database and your BCO pulls it off that.  You can do it any time before the final completion point, but it does need to be lodged on the database by a registered assessor before you'll get your completion certificate.
You can do your own SAP calcs and send the completed data set to an assessor to lodge for you.  I did this, but the saving was modest - the assessor still charged me £100 +VAT to lodge the report I'd produced.  No one other than a registered assessor can access the government data base to lodge the report, so you're pretty much stitched up when it comes to trying to do the job yourself.
