1 hour ago1 hr Plan A: batten out beneath posi joists with 22x100mm planks for plasterboard to sit on.Potential problem; I’m wondering of the posi joists will be in the way of the down lights… I suspect in some places they will be. Do people usually batten out enough for down lights to go anywhere in ceiling or do work around the joists?
1 hour ago1 hr You have two options work around the joists or work around the battens, either way you are working around something. But doing 22mm battens you will most likely be working around joists and battens. Use deeper battens if you are doing battens?
1 hour ago1 hr Author 12 minutes ago, JohnMo said:You have two options work around the joists or work around the battens, either way you are working around something. But doing 22mm battens you will most likely be working around joists and battens. Use deeper battens if you are doing battens?Thanks… any suggestions on thickness of battens needed? I’m conscious I don’t want to reduce the ceiling too low.
35 minutes ago35 min We used 45mm gave enough room for shallow down lights and the inverter that came with them. But it was designed that way from the start, as I am insulated between pozi joists and have an AVCL under the pizi also (single storey)
Just now1 min We're only 2400mm ceiling height so are working around the posis, 45-50mm seemed like too much height to lose, especially as we won't have recessed lighting everywhere
