Cement board screws
Just discovered there is a screw for cement board.
Of course our builder used regular black plasterboard screws.
Does it matter? Do I bother replacing the screws before the tanking goes on?
Blimey, turns out its not cement board, its Resistant Multi-Pro MoistSure Tile Backer Board, which is a glass-fibre-reinforced magnesium oxide (MgO) board rather than a conventional cement board.
The manufacturer recommends stainless screws. Apparently Magnesium oxide boards can contain residual chlorides from their manufacturing process, which can cause corrosion of ordinary steel fixings under certain moisture conditions.
Should I get the screws replaced?
Edited by Mr Blobby
Absolutely. Personally I would do with cement board too but not done a lot of research on that.
I was quite keen on using MgO board for things so did a fair bit of research on it. You definitely want to use stainless steel screws with that. The warranty providers have stopped covering MgO in their warranties because of issues with them (though I think that's more for structural/external issues). Looking at this product it has full BBA approval so should be fine (a lot of the issues were caused lower quality boards). Still, moisture + non-stainless screws seems like a recipe for issues.
6 minutes ago, Mr Punter said:
If you are tiling I wouldn't bother messing with the screws.
yes tanking with schluter kerdi then tiling over.
Interestingly the manufacturer also suggests a line of silicone between the floor and the bottom board. That bottom board would be under the shower tray so sounds sensible but certainly not something our builder was planning to do.
Multi-pro-Tile-Backer-Board-Fixing-Guide.pdf
I can see this is as another job I will do myself. Good thing I have nothing else to do. 😕
