2 hours ago2 hr I have just started fitting cavity closers and one of the windows has the inner / outer openings the same size, but the outer opening is shifted 20mm to the left. This is obviously going to cause a real headache when then try and fit the windows and also when it comes to returning the plasterboard into the reveals. Is the only option to cut the inner leaf back by 20mm with a stone saw and then screw a piece of 20mm timber to the other internal face to correct the shoddy workmanship?
18 minutes ago18 min I used a length of timber screwed to the block with spacers to bring it level, then foamed it in. You can see it on the left in this photo.
Just now1 min Author 17 minutes ago, Super_Paulie said:I used a length of timber screwed to the block with spacers to bring it level, then foamed it in. You can see it on the left in this photo.So I'll cut one side back 20mm and pack out the other. Do these tradies have no shame. It's not rocket science.
