Thursday at 14:041 day Is there a standard tolerance for construction of internal doors? or a terms of reference that can be used?Many of our doors seems to be out of line - specifically, the legs/jambs and the header frames installed in new wall constructions. This of course is also affecting the doors.Thanks Edited Thursday at 14:051 day by Jothetaxi
25 minutes ago25 min Mr Punter is right, the one most people go by is the NHBC Standards chapter 9.1 "A consistent approach to finishes" and section 9.1.4 covers doors. LABC Warranty has much the same in the tolerances section of their technical manual if your build isn't NHBC.For internal doors the main figures are frames within 5mm of plumb over the full height, and not out of plumb in two directions (so not leaning into the room and along the wall at the same time). The gap between door and head or jamb max 4mm and it should be uniform. Door distortion max 5mm over the height and 3mm across the width. Gap under the door to the unfinished floor 10 to 22mm.Bear in mind they are written for checking a finished home at handover, so its the most that's acceptable, not what a decent joiner aims for. Most would set a lining dead plumb with a long level.If doors are binding or the gap goes from tight to wide down one side thats usually the lining twisted or the head out of level rather than the door. Put a long level on both legs, then run two strings corner to corner across the frame. if the strings touch hard or there's a gap where they cross, the frame is in wind. A twisted lining normally has to be refixed with packers at the hinge and lock positions, planing the door just chases the problemIf it's a new build under warranty I'd measure and photo each door and send it to the builder quoting 9.1.4
