Rationel Window - Water Ingress- Help!
Hi Everyone
Desperate for some advice on a bit of water ingress coming in at floor level cill during heavy rain.
We had Rationel windows installed as part of our timber frame contract. They have been fine generally but one tall fixed light widow has a small amount of water ingress. I have tried adding CT-1 in a few places but the problem persists. The walls have been clad externally with fibre cement board and then rendered with Baumit Silikontop. The walls have now been plasterboarded and skimmed ....then the problem came back when it rained. I have been racking my brain trying to figure out how the water is getting in so any advice would be most welcome.
Here's the detail from Rationel with my notes added:
Here are some photos of the current situation:
Internally damp patches showing through the levelling compound and external view of cill
Here's a 3D of the detail...
What can I do, preferably without ripping of the render and boarding to investigate?
I have had the same problem in the past. It was caused by wind driven rain being forced through the small gap, shown by red arrow, when the sealant wasn't fitted properly. Is the leak only when the wind is in one direction? Pack the gap in the corner with something waterproof and removable, such as a piece of closed cell foam, to check the cause. It can be filled permanently with CT1 well masked.
Edited by Gone West
