23 hours ago23 hr Hi, got a major problem with my disinfection cycle which makes no sense to me, On my LG 9Kw heat pump controls I set the disinfection control to come on at required time and for 1 hour to get water temp up to 60°C When the required time is reached I hear the solenoid click in for the immrsion heater, after 1 hr the temprature has risen about 2° C. the water temp was 50°C to start with.I have checked the flow of current to the immerson heater with a clamp meter which is a healthy 13.5 amps, I have checked the resistance of the immersion heater element which was 19 ohms, I have two more thermometers in the pocket of the water tank which also only rise 2° in 1 hr. I have also tried to check the thermostat on the immersion heater , which does switch on and off and is turned up to the top.Anybody got any Ideas what to check next. Thanks
10 hours ago10 hr Are you sure the bottom of the immersion reaches down to the level of the temperature sensors?? The immersion will only heat as far as it reaches down. If youve seen it drawing 13amps then that energy has to be going somewhere either heating the water in the cylinder or heating water that is being constantly drawn off.
6 hours ago6 hr Have you monitored the current over time? Is the immersion switching on and off (thermally limited by it's internal thermostat)?How old is this install? Live in a hard water area?Scale build up around heating elements can reduce heat output. Though it only slows it down doesn't make the heat disappear.
1 hour ago1 hr Author 5 hours ago, -rick- said:Have you monitored the current over time? Is the immersion switching on and off (thermally limited by it's internal thermostat)?How old is this install? Live in a hard water area?Scale build up around heating elements can reduce heat output. Though it only slows it down doesn't make the heat disappear.Hi, I am going to change the immesion thermostat to see if that helps, the instal is only 2.5 years old,but to be honest I dont think it worked from new, we dont live in a hard water area
1 hour ago1 hr Just now, Potatoman said:Hi, I am going to change the immesion thermostat to see if that helps, the instal is only 2.5 years old,but to be honest I dont think it worked from new, we dont live in a hard water areaThat sounds a bit like jumping the gun. If you've measured the full 13A current draw then the thermostat was working when you measured.My question was more around whether the thermostat is turning the immersion on and off (ie, it thinks the tank is to temp) when the tank is not to temp. If that is happening then it might be that the immersion has thorough scaled up and can't shed the heat fast enough.
30 minutes ago30 min Author 9 hours ago, Dillsue said:Are you sure the bottom of the immersion reaches down to the level of the temperature sensors?? The immersion will only heat as far as it reaches down.If youve seen it drawing 13amps then that energy has to be going somewhere either heating the water in the cylinder or heating water that is being constantly drawn off.Good point about the energy going somewhere, not sure where though,. The immersion heater is fitted at the side 4/5 the way down and the pocket for the temperature sensors is about 3/4 the way down directly above the Immersion heater .
19 minutes ago19 min How big is your tank?Do you have a pumped loop hot water system that is active or even an accidental thermosypon that is dissapating the heat?
Just now1 min Author 1 hour ago, -rick- said:That sounds a bit like jumping the gun. If you've measured the full 13A current draw then the thermostat was working when you measured.My question was more around whether the thermostat is turning the immersion on and off (ie, it thinks the tank is to temp) when the tank is not to temp. If that is happening then it might be that the immersion has thorough scaled up and can't shed the heat fast enough.I supose it could be, but we dont live in a hard water area, its only 2.5 years old and I am not sure but I dont think it has been working since new. As for changing the thermostat,I am just running out of ideas,going to change the immesion heater next, if that doesn't work.
