what %% for humidity?
I've got vent Axia Kinetic, but I'm struggling what to set the humidity to.
I've had it mid 60% for the last few years, just to stop it running on boost for so long, but with another aluminium windows getting condensation on the north side of the property again (whenever it gets to near freezing) I tried to drop it to mid 50% and leave it there for a week or two.
However, it just sits at boost for the entire time...I don't understand how some people can keep their property at lower humidities without the fans running so hard all the time?
Just welcome any advice over how others run them!
Think we have low 50s setting for boost, but it's currently cold (zero outside) and actual humidity in lounge is 38%. Our MVHR almost never goes in to boost. In winter the issue should keeping humidity high enough to be healthy. One of the reason people use enthalpy heat exchanger (not really needed in UK) as we do not have prolonged cold periods like central Europe.
The aluminium windows can't be thermally broken or you have cold bridging around the frame leading to moisture build up. I would start looking for the route cause take temperature measurement around whole window surround looks for cold areas.
Wetroom : 84% ish as boost comes in, then down to 50 - 55 or so most days by the time I'm dressed. Thereafter, I don't take much notice of RH - although I have 6 RH meters dotted round the house because SWMBO is concerned that the lower than 'normal' RH will adversely affect the Triffids she grows on our mezzanine. And when I ask her what 'normal' is I get the classic
"I should have thought that was obvious"
16 hours ago, Andeh said:
...I don't understand how some people can keep their property at lower humidities without the fans running so hard all the time? ...
Our system seems to tick over quite happily. Perhaps thats because I don't care about RH ? The wetroom floor dries quite quickly on its own, towels dry quicker with the system running than not. On the advice of others here in this section of BH, I specified a unit capable of dealing with an internal volume just under twice our own.
