22 hours ago22 hr Hi all. New here! I’ve spent a bit of time reading posts and searching relevant topics but I still can’t find the answer I’m looking for….1950’s bungalow. Cavity walls with 50mm cavity, block in and out. Bare block inside as panelling has been removed. Rendered and painted externally and external insulation not possible.I want to increase insulation for better heat retention as considering installing an ashp.I was thinking of having the cavity insulated with beads blown in and then inside line the walls with 50mm PIR in between 50x50 timber frame attached to walls, vapour barrier and 12.5 p/board and skim.I’ll also be doing a loft conversion so will have good ceiling/roof insulation. Flooring is suspended so I plan on fitting 75 or 100mm between joists.Does this sound a good idea?Thanks
21 hours ago21 hr Is it worth the bother of insulating the cavity if it's only 50mm? Could you not simplify the internal insulation with insulated plasterboard attached direct to the wall?
21 hours ago21 hr Author Hi John.I wanted to insulate the cavity as it would make a small benefit to overall insulation.Inside I thought if I sit the insulation tight against the block there wouldn’t be an air gap which you’d get with dot and dab insulated plasterboard.Another consideration is should I be insulating internally as I’d be losing the thermal mass of the blocks and from my limited understanding of ashp is thermal mass is beneficial.
21 hours ago21 hr 53 minutes ago, Simon85 said:50mm PIR in between 50x50 timber frame attached to walls, vapour barrier and 12.5 p/board and skim.Welcome.That's a decent plan. Although 50 x 50 could be reduced. Metal stud is an option. You will also be able to put any new wiring along the wall first.Thermal mass is a comfort thing, but insulation is an efficiency.Will the heating be in the floor or where?
21 hours ago21 hr Welcome!6 minutes ago, Simon85 said:Hi John.I wanted to insulate the cavity as it would make a small benefit to overall insulation.Inside I thought if I sit the insulation tight against the block there wouldn’t be an air gap which you’d get with dot and dab insulated plasterboard.Another consideration is should I be insulating internally as I’d be losing the thermal mass of the blocks and from my limited understanding of ashp is thermal mass is beneficial.Starting with the last bit first (!): Is your internal block skin lightweight, heavyweight or medium? Certainly if it's lightweight I don't think you'll lose much 'thermal mass'. I would be minded not to use battens, but I would parge the wall in lime first. Do bear in mind that purveyors of insulated plasterboard assume (a) VCL is 100% tight - an extremely rare thing - and (b) that the structure can 'breathe' outwards. As it is rendered and painted the breathability may be somewhere between OK-ish and not good at all.@JohnMo suggested insulated plasterboard. My suggestion would be similar, but (unless I had persuaded you to use wood-fibre and lime plaster) I would use 'raw' PIR over a parge coat, which allows you to tape the joints and perimeters as VCL first. Yes, it's a pernickety point but at the edge of each sheet of insulated plasterboard there is no VCL. Using separate insulation and plasterboard allows a pretty good VCL. Then drill and hammer-fix (Ejot are great). Accepting that holes are not a great part of a VCL you would use a 'plaster-onto' 'fluff' tape such as Pro Clima 'Contega' or Pavatex 'Pavafix Win' over the fixings.Of course this leaves you nowhere for cables so either:Get to like surface-mounting orPut all the elecs on internal walls!I'll do a rough U value calc for the 50 EPS and 50 PIR later. *Got in inside the 'editing window' so I can do it now. U value with the block/graphite /EPS/PIR 'sandwich' you should get about 0.22W/m2K (vs likely current U value of 1.5W/m2K). If you take the view that lower than 0.5 (or some say 0.35) puts you in the interstitial condensation risk zone then at very least get an interstitial condensation risk analysis. Note the Glaser (British Standard) method is a bit 'blunt', but very widely available free (your insulation merchant may do it for you). WUFI (Warme und Feuchter Instationaar) IIRC, is much more dynamic and accurate. Edited 21 hours ago21 hr by Redbeard U value estimate
20 hours ago20 hr 16 minutes ago, Redbeard said:but (unless I had persuaded you to use wood-fibre and lime plaster)36 minutes ago, Simon85 said:thermal massNot a term used on here lightly - many a long discussions. Heat loss is heat loss, a house needs the same number of kWh's heat as that lost. What changes is the time period to move temperature from one temperature to another and time taken to fall back again. A lightweight structure heats fast and temp drops fast, heavy weight structure has lots of material to heat not just the air so reheat times are long, but cool downs are also long. Does it make a difference for a low and slow heating system not really.Lightweight blocks store almost no energy so are a lightweight structure. PIR insulation is very lightweight. But wood-fibre can be a good compromise. Assume you attach direct to brickwork and then lime plaster as @Redbeard says. To keep the structural vapour open don't use normal emulsion paint which vapour closed.
17 hours ago17 hr Author 3 hours ago, saveasteading said:Welcome.That's a decent plan. Although 50 x 50 could be reduced. Metal stud is an option. You will also be able to put any new wiring along the wall first.Thermal mass is a comfort thing, but insulation is an efficiency.Will the heating be in the floor or where?Heating will probably be in the floor
17 hours ago17 hr Author 3 hours ago, Redbeard said:Welcome!Starting with the last bit first (!): Is your internal block skin lightweight, heavyweight or medium? Certainly if it's lightweight I don't think you'll lose much 'thermal mass'. I would be minded not to use battens, but I would parge the wall in lime first. Do bear in mind that purveyors of insulated plasterboard assume (a) VCL is 100% tight - an extremely rare thing - and (b) that the structure can 'breathe' outwards. As it is rendered and painted the breathability may be somewhere between OK-ish and not good at all.@JohnMo suggested insulated plasterboard. My suggestion would be similar, but (unless I had persuaded you to use wood-fibre and lime plaster) I would use 'raw' PIR over a parge coat, which allows you to tape the joints and perimeters as VCL first. Yes, it's a pernickety point but at the edge of each sheet of insulated plasterboard there is no VCL. Using separate insulation and plasterboard allows a pretty good VCL. Then drill and hammer-fix (Ejot are great). Accepting that holes are not a great part of a VCL you would use a 'plaster-onto' 'fluff' tape such as Pro Clima 'Contega' or Pavatex 'Pavafix Win' over the fixings.Of course this leaves you nowhere for cables so either:Get to like surface-mounting orPut all the elecs on internal walls!I'll do a rough U value calc for the 50 EPS and 50 PIR later. *Got in inside the 'editing window' so I can do it now. U value with the block/graphite /EPS/PIR 'sandwich' you should get about 0.22W/m2K (vs likely current U value of 1.5W/m2K). If you take the view that lower than 0.5 (or some say 0.35) puts you in the interstitial condensation risk zone then at very least get an interstitial condensation risk analysis. Note the Glaser (British Standard) method is a bit 'blunt', but very widely available free (your insulation merchant may do it for you). WUFI (Warme und Feuchter Instationaar) IIRC, is much more dynamic and accurate.Thanks. Now you’ve blown my little brain!The blocks are medium density.Are you suggesting I fix the plasterboard with ejot fixings? I’m not sure if they are suitable for this.I had read a bit about interstitial condensation. I understand what it is but working out where the dew point is is a bit beyond me. I was hoping someone would just reply saying yes that’s all fine or just do either the cavity or the internal PIR insulation!
17 hours ago17 hr Author 3 hours ago, JohnMo said:Not a term used on here lightly - many a long discussions. Heat loss is heat loss, a house needs the same number of kWh's heat as that lost. What changes is the time period to move temperature from one temperature to another and time taken to fall back again. A lightweight structure heats fast and temp drops fast, heavy weight structure has lots of material to heat not just the air so reheat times are long, but cool downs are also long. Does it make a difference for a low and slow heating system not really.Lightweight blocks store almost no energy so are a lightweight structure. PIR insulation is very lightweight. But wood-fibre can be a good compromise. Assume you attach direct to brickwork and then lime plaster as @Redbeard says. To keep the structural vapour open don't use normal emulsion paint which vapour closed.Not a method I’m keen to use
Just now1 min 17 hours ago, Simon85 said:Not a method I’m keen to useWood fibre?OK, then if you decide to use PIR most insulation merchants will offer (if asked) to do a Glaser Method Condensation Risk Analysis (less accurate than WUFI but better than nothing). They'll work out the dew-point for you and send you a nice graph.17 hours ago, Simon85 said:Thanks. Now you’ve blown my little brain!The blocks are medium density.Are you suggesting I fix the plasterboard with ejot fixings? I’m not sure if they are suitable for this.I had read a bit about interstitial condensation. I understand what it is but working out where the dew point is is a bit beyond me. I was hoping someone would just reply saying yes that’s all fine or just do either the cavity or the internal PIR insulation!17 hours ago, Simon85 said:Are you suggesting I fix the plasterboard with ejot fixings?Yes, but the plasterboard and the PIR together. Lightly 'tack' the PIR to the lime parge. Anything 'gloopy' would do, but I'd consider a full perimeter bead of silicone mastic with cross-hatchings. Drill the holes thro to the masonry before the mastic has 'gone off' and hammer the fixings home. At worst you'll need a slightly thicker skim to cover the heads.
