Help with towel radiator plumbing
Hi everyone,
I’d appreciate some advice on replacing a towel radiator and making sure I have all the necessary parts ready for installation.
My existing Apollo Pavia chrome towel radiator has rotted, and I’m replacing it with a Reina Helin stainless-steel towel radiator:
* Existing radiator: Apollo Pavia
https://www.homesupply.co.uk/Apollo-Pavia-Chrome-Tube-On-Tube-Towel-Warmer-800-x-500mm
* Replacement radiator: Reina Helin
https://www.radiatorworld.co.uk/reina-helin-stainless-steel-designer-heated-towel-rail
The pipe centres on my existing Apollo are 450 mm. The manufacturer lists the Reina Helin’s pipe centres as 460 mm, but some sellers say they're 450 mm, so I’m unsure which measurement is correct.
My plumber isn’t available to advise at the moment, and I need to have all the necessary parts before installation. Could anyone help with the following?
1. Can you confirm whether the Reina Helin’s pipe centres are 450 mm or 460 mm?
2. If they are 460 mm, what adaptors or fittings would be needed to connect it to fit my existing pipework, which has 450 mm centres?
3. Will I need new valves, or could the existing ones be reused? If I need new ones, what type should I buy?
Thanks for your help.
All depends on the piping layout and length from coming out of either floor or wall. 10mm is very little in plumbing terms but that depends on pipe length.
Yes, installation guide appears to say 460mm, bad luck. If you could find one in a showroom then you could measure it.
It took us ages to find one to match our existing pipe centres (420mm from memory) and greatly restricted choice.
Our pipes come out of the tiled wall because we have it mounted above a worktop. Fortunately I had spare tiles in the loft and as they were mosaic's was easy to chisel off and replace a couple of tiles to make a tidy job.
Reina-Helin-Installation-Guide.pdf
