Yesterday at 10:071 day Hi All, I'm after some advice if you can help. The shower tray in our bathroom has cracked - this approx 2 years after it was installed. The resin tray has a bounce to it around where the cracks are, so it clearly has not been installed correctly by the plumber. (The tray sits on a concrete slab, so any bounce must be because there is insufficient sand/cement or adhesive beneath the tray). The plumber was a sub-contractor, so I didn't pay him directly for his work. The main contractor we fell out with at the end of the build as they tried to charge us a lot of money for their own mistakes, so there is absolutely no way we can approach them. I approached the plumber directly about 6 months ago about this and he seemed quite reasonable: send me pictures etc, I'll speak to the supplier of the tray etc - but then nothing. I chased a few times - nothing. The only time he picked up the phone again was when I withheld my number. Surprise surprise.What can I do in this situation? Can the plumber argue that his "contract" was with the main contractor so I have to go through them? Can I get someone else to rectify then pursue him through small claims? Unfortunately the amount of work to rectify isn't small - the tray is butted closely with large-format tiles and there would be no room to remove it in one piece, so it would need to be cut up in-situ. Likewise I can't see how a replacement could be easily slid back in, I think we will have to tile over a wet-room former.Any advice gratefully received, thanks
Yesterday at 10:181 day I think you will struggle to get anywhere with this. It would be hard enough if the main contractor was amenable.I have had a tray replaced in the past and it involved hacking off the tiles from the bottom, cutting the tray out, repairing the walls and re-tiling. Hell of a mess.
19 hours ago19 hr Sorry to hear it OP, shit situation indeed. I think you're going to need to take it on the chin realistically. :(
3 hours ago3 hr Given the amount of work that would be required to replace it, have you explored a repair? Resin trays can be repaired, but you'd probably need to inject something to fix the support issue too. Might be worth a shot.
