Well this is fun
Setting out only need to worry about the through route - the bond right to left as you look at it will be random (ish)
Just for a bit of fun - B&Q Kitchen with own brand "Homark" appliances fitted in 1995 - I've got the original bill of sale somewhere but it was under £5K all in...............
Oven failed first 20 years after install - not so much a fail to cook more a door hinge failure leading to a door glass breakage - cheap Zanusi (in stock at Currys and less than £100 and fitted in the hole were purchase criteria) got thrown in because Mrs Alien was working and it was my job to put the Sunday roast on so it was ready for when she finished work - I was putting the roast in when the door fell off)
Obviously this was a surprise to Mrs Alien - so I broke the news gradually with good news bad news
Good news darling - you don't need to clean the oven this month (She hates cleaning ovens)
Even better news darling - that oven you moan about cooking bread or cakes that never come out right - I've bought another one
Bad news darling - we are £100 down in the current account
(Oh and this one still doesn't cook bread or cakes very well either - I'm wondering if it is the oven at all)
Integrated Fridge next - 21 years after install - Fridges should keep stuff cold and this fridge did a good impression of a warming drawer - a mate is a refrigeration engineer and I asked if he'd take a look - apparently 21 years is (expletive deleted) off territory as far as fixing goes.
Dishwasher failed next - 23 years after install - tablet dispenser drawer broke - so we resorted to turning on a timer and throwing the tablet in after 8 mins (we lived with that for 3 years - I could live with that longer but the pump failed and so a second hand £50 (non integrated Bosch one got thrown in the hole) (I kept the integrated door from it - you know just in case she changed her mind)
It was at this point that Mrs Alien was already mumbling on a regular basis about a "New Kitchen" so at that point any appliance replacement would have to be either
a) second hand
b) bloody cheap
Most recently last year the "homark" gas hob failed - the sparky sparky thing failed and lighting it with a match or lighter wasn't deemed acceptable - ebay got me a new hob for £50 cos it didn't have "auto shut off" gas valves and apparently not suitable for rental properties so cheap!!!
I think they all did rather well - However Kettles are a whole different story and we've probably had more than 30 since the kitchen was fitted - stupid hard water area and Mrs Alien does a weekly descale with vinegar - which cleans the element but shortens it's life.
Edited by marshian
Missed a bit
Todays fun times
Just the cuts at each end to do
On 16/11/2026 at 17:48, Spinny said:
for Christmas 2027.
You need to stop taking the drugs and go cold turkey 🤣
I still think it will be fine 😄
I will admit I had hoped to have the tiles down and grouted and the worktops removed but a little slippage is normal
Doing fine so far. Your gate seems to be the measuring of the worktop. Miss that and you might be in trouble. But if you keep your existing one safe somewhere I'm sure you could make it work in a temporary fashion if it came to it.
Yeah that's the critical window - existing work top and sink is a planned upgrade for the Utility so isn't going anywhere yet.
Of course there is also the walls to re-plaster/skim because Mrs Alien thinks they will be a mess when the tiles come off - EasyFill and a large float and I can hide most things 😄
Oh and now the ceiling has got to come down at some stage before the kitchen fitting starts........ apparently "I" should have realised that she would want downlighters........ the ceiling joists run the wrong way to do it easily.
I do love a bit of scope creep from Mrs Alien.....
Oh!
That one is a doozy. Have you tried suggesting some fashionable track lights?
Well I could lift the spare bedroom floor up (again) but guess what it's being used for......................
there is a lot of stuff in a kitchen and it's gotta go somewhere...........
Floor finished
7 whole tiles left so my 15% overage should have been closer to 5% I could store them in the plinth drawer 🤣
radiator moved to where it doesn't get hit by the door
Next remove the worktop/sink and safely relocate because this truck turned up on time
Which meant all the kitchen units are in here
Still useable as a living room just shrunk to half it's normal size
Mirror on left and fireplace on the right are half way down the room
The appliances went in the garage cos there are two project cars in there
4th Dec doesn't seem far away!!!!
You like living dangerously?
Sort of but on balance probably not
there are two reasons I could
  1. She has the memory of a goldfish so has already forgotten it's there so hasn't used it yet
  2. She might remember it's there one day
And one reason I won't - the tiles are too long!!!
Underneath the kitchen units it is then - same as spare tiles for the old kitchen went
Incidentally spare tiles for bathroom are under the bath and I had no tiles left for the en-suite and if I had they wouldn't go under the shower!!!!
Tile storage like this is normal right???
ive got plenty of kitchen plinth stashed behind the installed plinths. Easier to hide it than get rid of it and might come in handy for god knows what.
If i had a plinth drawer in my plinth id store my plinths in the plinth drawer, thats for certain.
This continues to be one of the more entertaining threads in recent memory. Well done everyone!
Indeed as per title it's a bit of fun and you can all laugh with me or at me - I'm easy with either or both......
At you, would give the most pleasure. Lol.
Use the spare tiles to make the skirting boards. This looks smart, needs no painting, zero maintenance etc. I did those size tiles for a previous client (140m2 of them…..) and we cut the tiles down to 120mm and kept the factory edge up top. Mitred the corners, looked the dogs danglies.
@Nickfromwales I was honestly thinking about doing that as there is so little skirting board once the units are in.
In other news
All the wall tiles are gone and the ceiling fell down.... with a little help from a roughneck wrecking bar
So as they say "That escalated quickly....."
Strangely the kitchen is one of the hardest rooms to heat, 2 external walls, North facing and gets very little sun, our main entrance door is in it and a fairly old spec UPVC double glazed window.
When i did the heat loss calcs the double panel vertical rad is well oversized even at the flow temps I run - I'm thinking as I'm here put some insulation in I know it's in the heated envolope but the bedroom above is s spare room and gets much warmer so we have to run a much lower flow rate thro it than any of the other bedrooms thar are the sane size and have the same sized rads
Stupid Idea????
In other news
Stupid Idea????
Fluffy stuff on a roll is cheap as chips, so stuff it full as. Draught management will be more important, so if you do make lots of holes for spots see if you can get enclosed fittings or seal up the flooring to prevent heat rising by tenting.
Got almost full sheet of 100mm Kingspan was gonna use that first as it'll clutter up my garage forever more if I don't use it - it'll probably be better above the down lights but fluffy stuff can do the rest
Think PIR might make it noisy from above, like a drum effect?
I used acoustic wool in my 1st floors, and the bathroom got acoustic wool and then a thin PIR but that was just because there's UFH up there.
Interesting point - whole house has 75mm PIR below the ground floor and when I'm in the crawl space I can't say that Mrs Alien doing her elephant impression around the ground floor - nothing down there to absorb the sound
It's a spare room - was originally Bedroom 1 but when we extended the house it became bedroom 2 - it is occasionally use when we have guests stay - I think I'll take my chances and at least use up the PIR and concentrate on where the down lighters will be initially
Just been thro my garage trying to find my reel of lighting twin and earth and failed miserably - so I might have to bite the bullet and buy some tomorrow
