Geberit Leak
After years of service the concealed Geberit cistern appears to be letting by with a small trickle of water going into the pan. Took it all out just now, descaled and refitted. Everything appeared in good nick.
Is it the white washer, top left that's the likely culprit? Or something down inside the cistern when the below bits are removed?
The white flexible washer is usually the thing. You can try cleaning it and reversing it. New ones often available online. Though this is all generic info, assume that Geberit is the same but not used personally.
Geberit syphon washers of a certain age had a "fault" where over time they blistered - you can usually see a bubble or two in the surface - and causes it not to seal completely. Its the one you've identified. Simply changing it for a new one solves the problem ... and the latest ones seem to not suffer blisters like the old ones did. I've had to replace several. Annoying, but a cheap and simple fix.
