Just now1 min Installing a number of panel radiators on my project, and unfortunately some of the grounds (within the timber stud walls) for the hanging brackets are in the wrong position.It's my own fault as in a few instances I position the grounds for say a 1000mm wide rad, where a 1200 wide rad is being installed.It can be overcome by opening the wall, installing more grounds and reboarding, reskiming but understandably I want to avoid that.Not keen on radiator support feet either tbh.Does anyone know if brackets with an extra wide wall plate are available as I think that my bridge the offset of ground to radiator hanging lug. Perhaps I could just buy some metal and bend some up myself.Welcome any members ideas of how to overcome this issue?
