October 6Oct 6 1 hour ago, kandgmitchell said: Trouble is the installer does presumably do this but then leaves the system set as they feel is appropriate. A short briefing on the the operation, the manuals (mostly installation rather than operation)handed over then off they go. Two years down the line how does one assess whether that set up matches your lifestyle. Finding accessible information that is understandable to tweek the system is hard. Many posters on here have got a very detailed knowledge of the operational side of these units whereas some of us are loathe to fiddle too much; especially just before the heating season........ What the installer feels is appropriate should be based on what you told them you want......did you get what you wanted originally and your lifestyle has changed that you need/want to change things 2 years down the road??
October 6Oct 6 The pump came with the house package so there was no discussion with the installer prior. The didn't know me from Adam. The house functions well but with energy costs so high you have to wonder if the set up is performing at it's most efficient. Seeing other examples of energy usage for comparable homes does help to put it into context.
October 6Oct 6 2 hours ago, kandgmitchell said: I think this just makes my point....................... I don't think it does - maths is just maths Whenwe bought the house it was 23,000 kWh of gas annually - I got it down to 16,500 kWh of gas a year for CH and HW with typical home improvements before I started my optimisation efforts - I reduced it to 8,500 a year (with scheduled heating) but it's now stable at 10,250 running 24/7 with a DHWP and WC set up (I'm running a gas boiler like a heat pump) Latest change should see me back below 10,000 within a year
October 6Oct 6 55 minutes ago, JohnMo said: like reading technical manuals, do it for fun, but the general UK public doesn't I've just had 2 single room aircons installed in our Spanish place. One Mitsubishi, one Fujitsu. These are simple units of one inside and one immediately outside. I got out the manuals with enthusiasm. Switch on remote control, Select temperature. The louvre directions can be altered. That's it. X 25 languages. That's impressive really. In among it all was a small tech table with the efficiency and other stuff. The installer pointed out the condensation pipe outside and suggested a plant pot under it. What is very Spanish about it is that the two units (4 machines) are powered from one plug, into a wall socket.
October 6Oct 6 5 hours ago, kandgmitchell said: The pump came with the house package so there was no discussion with the installer prior. The didn't know me from Adam. The house functions well but with energy costs so high you have to wonder if the set up is performing at it's most efficient. Seeing other examples of energy usage for comparable homes does help to put it into context. Assuming the HP came with a new build 2 years ago then it will likely have a controller or app that will display COP or SCOP. Have a look at the user manual and find the COP/SCOP. Once you've found that value look up the HPs data sheet and compare your value to the values in the data sheet. If you've got a value near the top of the range(higher value is better) then you're doing OK and you'll have to teach yourself alot to improve things for what may only ever be a small gain/saving. If youre lower down the range then the gains/savings may be greater and worth your while reading up on HP efficiency so you can assess your system and make changes. Finding out your COP/SCOP is the first step.
October 7Oct 7 Author 16 hours ago, marshian said: Whenwe bought the house it was 23,000 kWh of gas annually How big is it, is it new build. For comparison.
October 7Oct 7 6 minutes ago, Post and beam said: How big is it, is it new build. For comparison. Early 1980's build 4 Bed Detached with 113 m2 of floor area across 2 floors (Garage not included) Background in a thread below
October 8Oct 8 On 06/10/2026 at 17:07, marshian said: Whenwe bought the house it was 23,000 kWh of gas annually - I got it down to 16,500 kWh of gas a year for CH and HW with typical home improvements before I started my optimisation efforts - I reduced it to 8,500 a year (with scheduled heating) but it's now stable at 10,250 running 24/7 with a DHWP and WC set up (I'm running a gas boiler like a heat pump) Latest change should see me back below 10,000 within a year Ouch, good effort. Similar size 90's house here heated to 21°C 24/7. A little over 13MWh annual heating and hot water demand. Ashp delivered this with ~3200kWh for a total cost of £519, £358 cheaper than using gas. Cop of 4.1. Edited October 8Oct 8 by S2D2
