Gulleys on patios
There must be a prettier option than having this on my patio?
Edited by Mr Blobby
20 hours ago, Mr Punter said:
If it is for surface water, a slot drain can look very neat.
Its to connect to the waste from the basin, I'm told its unavoidable.  I have seen some stainless steel covers that might be a bit less bad.
Personally, I don't like to see waste pipes so I've run all of mine internally, but if it's too late for that option I'd fit a low back p-trap below ground level and stick a connector into it (link below) and drop the basin waste straight into it.
https://www.screwfix.com/p/mcalpine-push-fit-1-inlet-offset-drain-connector-110mm/871JG?tc=EA3&gclsrc=aw.ds&gad_source=1&gad_campaignid=19822796606&gclid=CjwKCAjwwrPVBhA1EiwAv_YO-dSEbUlrmUKGFlScMHRt7E73LS3CCRkUxqpoD9aUgigeLRbQqVx4rhoCJNoQAvD_BwE
Edited by Roundtuit
2 minutes ago, Roundtuit said:
Personally, I don't like to see waste pipes so I've run all of mine internally, but if it's too late for that option I'd fit a low back p-trap below ground level and stick a connector into it (link below) and drop the basin waste straight in.
Sorry, I wasn't clear.  The waste is through the slab and exits underground.  From the cloakroom basin.  Builder says we need a gulley trap like this on the patio, one side connecting to the basin waste underground, the other to the manhole.  Seems the done thing here in NI.  Which is a shame.
