Dazz71 Posted 5 hours ago Posted 5 hours ago Hi everyone. So, here we go, we are in the midst of renovating a 1890s bungalow and are wanting to fit an mvhr system pretty soon. At the moment we've put in underfloor heating. Heatpump. Insulation etc etc. My question is about the mvhr unit itself... Would it be a good to sit it on its own heated concrete plinth/slab in the roof? Or should I forget that idea and just install a loop directly in to the unit? Or both? Or neither? Would it be a good idea to 'build' an insulated room around the mvhr unit itself? Because of where we are at with the renovation then I can pretty add what is needed as I go along. It wouldn't take too long to add strength to the joists, add an extra heating loop to our underfloor heating manifold specifically for the mvhr unit. Good idea? Terrible idea? Any insight, or other ideas are most welcome. Cheers.
Mike Posted 3 hours ago Posted 3 hours ago Welcome to the forum! 1 hour ago, Dazz71 said: Would it be a good idea to 'build' an insulated room around the mvhr unit itself? If the loft is the only place it will fit, then installing it within an insulated but unheated enclosure is good. Your loft access trap also needs to be big enough to get it through, and you'll need good access for filter changes & other maintenance. And, although good MVHR units don't make much noise, I'd not put it directly over a bedroom if there was an easy alternative. If it will fit within the heated envelope - utility room, kitchen or elsewhere - then that would be preferable. No need for a heating loop unless you're planning to use it to feed a duct post-heater to top-up the air supply temperature. That's not often done except when the MVHR is used as the main source of heating in Passivehaus. BTW, if you've not already picked it up, add airtightness to your to-do list. It's likely to be the most cost-effective improvement you can make & it plays a major role in protecting the fabric of the building from potential moisture damage.
