MortarThePoint Posted 6 hours ago Posted 6 hours ago Does anyone know where I can get the type of tee shown in the image below? It has two male 22mm connections and one female 22mm compression connection. I would also be happy with a tee that is 22mm male connections all round as I'll be connecting to Hep2O so that would save using a couple on each side.
MortarThePoint Posted 2 hours ago Author Posted 2 hours ago Based on the parts I have (2no. 22F x 3/4M full bore valves and 1no. 22F x 22F isolation valve) the best would be a 22M x 22M x 22M tee. In other words, a tee with all connections as plain 22mm pipe. I know I could make such a thing using a conventional tee and soldering, but it would be nice if there was a premade one since each connection made has a chance of failure.
