Inspection Chamber reducers (sizes query)
My groundworker has suggested reducing the diameter of the two large inspection chambers which will be in our rear garden down to 450 or 300mm.
So, I've been looking for a "reducer". The current twinwall chamber pipes that are in the ground measure about 680mm internal and 700mm external. I can't lay my hands on an invoice for said inspection chambers (one that won't be on the VAT reclaim!)
The largest reducer I can find online is 600mm (to various smaller sizes).
Should I be able to find a 700mm version?
Cheers
Bamboozled of Botus
More sleuth work has found two unaccounted invoices (yay for the VAT).
Interesting thing is that the chambers are listed as 600mm !!!
2 minutes ago, Alan Ambrose said:
Could they have got a bit oval? I had a problem exactly like that way back.
Maybe. I have two of them and have measured both, each across two diameters, so I think they're pretty much round.
NOTE: the invoice lists both as 600mm. For now I am assuming that they are classified as 600mm.
Its a bit like when you buy wood - nominal vs actual size 😀
