Insulated suspended concrete floors.
10 minutes ago, saveasteading said:
Please remember we aren't obsessed
That's not the impression I get when reading this forum...🤔
Sometimes you have to accept reality.
I'll throw in another option then:
20mm XPS with 18mm solid T&G floor screwed down into concrete?
Thin, no bounce.
Edited by tetris
  • Replies 52
  • Views 1.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • saveasteading
    saveasteading
    No offence was intended, and I, probably others too, are aware that a  discussion, even when off course.  may be looked at by many more people than we see. A tweak on the rudder can remind everyo
  • Russell griffiths
    Russell griffiths
    I did block n beam with standard concrete block and insulation on top, I looked at all these insulated types and concluded that they had two many faults.  harder to construct being a major one, stan
  • Nickfromwales
    Nickfromwales
    In my daytime role I provoke discussion, rake over everything robustly, and most of the time this is done inoffensively, to get all the options and possibilities on the table.   Some of my c
Posted Images
Alright I am passionate, and others my say obsessed. But for good construction, good value, correcting erroneous advice and simply helping people.
But not with a subject that just doesn't go away.
It doesn't go away because it's not resolved.
I value the marmox suggestion, but as I've already mentioned - it seems the manufacturer only approves <12mm thickness for laminate, and I can't find any reports of people successfully laying laminate over it. It's a lot more expensive per sqm than XPS 300, but appears to come with similar risks and less insulation thickness.
In regard to carpets, I appreciate that different people have different hygiene standards - I've once seen a house with a fitted carpet in the toilet - but I'm not considering carpet as a solution. For a couple of adults who always take the shoes off at the front door and spend half their life cleaning their city flat it might be OK. For an outdoorsy family with kids, pets, constant coming in&out of the garden carpets are a health & safety hazard from the amount of dirt that will build up in them.
