thaldine Posted June 25 Posted June 25 I'm intending to replace an existing dwelling with a new build home. The existing access track is over 100m in length, about 3m wide with a maximum gradient of 1 in 10 (although most of it is less steep) and is metaled with crushed stone. Due to the size, slope and nature of the site there is very little scope to widen it or the existing 8m x 8M turning/parking area at the top or add a new access from elsewhere. I believe there are various building regulation requirements regarding access that may be hard or impossible to comply with regarding width, steepness and emergency vehicle access. Does anyone else have experience or knowledge of similar issues and potential ways of remediating them ? The existing dwelling is built using heavily creosoted timber railway sleepers - so in my view it's ongoing use as a dwelling constitutes an existing fire hazard - though I'm doubtful application of the regulation will take any account of that !
LDNRennovation Posted June 25 Posted June 25 (edited) I have seen people add sprinklers to get over width and length access issues in roads. The roads were always basically accessible though. Best thing to do is direct contact with your local authority, it’s a replacement dwelling so anything you can do to improve the situation would be looked at kindly unless you get a bad planning officer. Edited June 25 by LDNRennovation
Mr Punter Posted June 25 Posted June 25 I have found that if there is an existing driveway and dwelling, unless your proposal makes the arrangement worse, highways, planning and the fire service don't get too busy with it.
kandgmitchell Posted June 30 Posted June 30 On 25/06/2026 at 17:49, Mr Punter said: highways, planning and the fire service don't get too busy with it. I'm sure they don't but Building Control who have to sign the building off as compliant with the Building Regulations might... Access and facilities for the fire service B5. (1) The building shall be designed and constructed so as to provide reasonable facilities to assist fire fighters in the protection of life. (2) Reasonable provision shall be made within the site of the building to enable fire appliances to gain access to the building
thaldine Posted July 1 Author Posted July 1 20 hours ago, kandgmitchell said: Building Control who have to sign the building off as compliant with the Building Regulations might... Indeed, my question was about building regulation requirements rather than planning - the planning permission has already been granted.
kandgmitchell Posted July 2 Posted July 2 Ah, sorry hadn't noticed the "Highland" location. Can't really say what the Scottish Building Standards say about access, but I agree it's a regs concern rather than planning.
