Post and beam Posted 22 hours ago Posted 22 hours ago Has anyone that is running cooling through their UFH heard any worrying noises from the underfloor slab? I initiated cooling for the first time a couple of hours ago. I just heard a dramatic sound that appears to have come from our floor. Coincidence perhaps and i have no idea what it is. Sounded like a dull crack. Quite loud to be honest.
JohnMo Posted 22 hours ago Posted 22 hours ago What is your flow temperature, how are you operating, more info needed
Post and beam Posted 20 hours ago Author Posted 20 hours ago Flow is set for a desired 12 degrees. Currently flowing at 11.5 degrees. Internal house temp has been 27 degrees for days. 30 degrees outside.
JohnMo Posted 20 hours ago Posted 20 hours ago First your flow temp is too low, you need to increase a couple of degrees to around 14 +. 12 is below dew point. If house is still at 27 you need to flowing about 16, until house cools. Work out your dew points - plenty of tool online. Cooling via UFH is the same as heating low and slow. Suspect the noise is likely to be the floor complaining about you trying too hard and contracting.
