Michael_S Posted April 22 Posted April 22 I would like an effective zero disruption install. I think I could use a 9kw Grant Heat Pump costing 3.3k inc VAT run the cabling and pipework myself and even position the unit (total cost about 5k?) so it would just need someone to connect the electricals at the meter end, sign off on everything, inform the DNO, confirm it meets the BUS requirements and whatever else in order to get the BUS grant. Even without this would seem cheaper than the 6k after BUS that I have been quoted. Thoughts?
JohnMo Posted April 22 Posted April 22 Umbrella route has been done by many. But everything is done via umbrella company with respect getting grants and paperwork, you do the work and report back, they may need to commission also. 9kW sounds big based on your other posts. If it's an R290 Grant, they don't do cooling. Have it confirmed from Grant technical. 1
Michael_S Posted 4 hours ago Author Posted 4 hours ago Just wondering how heat pump quotes are calculated. For example my quote of 6200+7500 for a zero disrupt install (no cylinder, no rads) with a heat pump costing 3.5k, a 10m cable run and a 3m pipe run just seems crazy unless I am missing something?
