deasonuk Posted December 27, 2025 Posted December 27, 2025 Previous late 90's house has had 40MM pipe running along in boxing that I'd quite like to remove in my bathroom refit if it's feasible and do a wall hung basin. Existing mains feed spurs off existing 22mm pipe directly up through the floorboards, I planned on spurring off this 22mm direct into the Stud wall. Waste outlet hole is 40mm to the soil stack. I plan on extending enough 40mm for the bath drainage and then for the sink basin I thought I'd be able to go 32mm from sink to 40mm and run this through the stud but reviewing a few posts it doesn't sound possible to put the pipe through Metal stud (Needing to drill for holes) and also will mean sound issues? (It will be 20/30mm Tileback to front. The fall is another challenge, the wall width is approximately 1500mm. Am I right/wrong on this and does anyone have advice on this ? Boxing would be possible but clutter this room big time so I'd really like to avoid this if I can sensibly and easily.
