tsf75 Posted November 5, 2025 Posted November 5, 2025 I have a Gecko "IN.Temp" 7.5KW hot tub heat pump. For the past couple of months, the pump has been exhibiting unusual behaviour: - The pump works perfectly well during the overnight heating cycle. The water is correctly heated and there are no issues. - during the day, the pump compressor is activating itself, approximately every hour, for around 5 mins. The coils are getting hot. The fan is NOT spinning. - after 5 mins, the compressor shuts off. It is shutting off because I think the coils have heated up and reached a cut off temperature. - this cycle repeats all day, every hour, every day - there are no errors reported - ambient temperature is around 15-18 celcius I've tried a few things, including the flow switch continuity, which is all fine. I am starting to think the pump is stuck in a continuous "Defrost" cycle. Anecdotally, I am pretty sure this behaviour started after a power cut in the area, a few months ago. So a fried component is not out of the question. Any ideas on what is causing this behaviour? I am also talking to Gecko support but they are extremely slow at responding and don't seem to be very interested now it is out of warranty.
tsf75 Posted November 5, 2025 Author Posted November 5, 2025 22 minutes ago, JohnMo said: Have you tried power off and on again? Thanks for quick reply. Yes I've tried this. I power-off the whole system frequently, during my investigations inside the heat pump..!
