kandgmitchell Posted October 27, 2025 Posted October 27, 2025 Had the first annual service today on my Vaillant ASHP. Glycol level checked and it's fine. However, the service engineer asked what glycol it was as they can't be mixed and to find out what it was for future reference should topping up be required. Having called the original installer they believe alphi 11 was used but it was certainly a propylene glycol. As long as any "top up" in the future is also a propylene product, is it likely to be an issue or do I need to nail down the exact product used in the system?
sharpener Posted October 27, 2025 Posted October 27, 2025 14 minutes ago, kandgmitchell said: As long as any "top up" in the future is also a propylene product, is it likely to be an issue or do I need to nail down the exact product used in the system? Wouldn't have thought so. More in this thread.
kandgmitchell Posted October 27, 2025 Author Posted October 27, 2025 Thanks, I did look all through that thread but couldn't see any mention of mixing different makes. One wonders if the additional inhibitors etc are happy to intermix.
JohnMo Posted October 27, 2025 Posted October 27, 2025 1 hour ago, kandgmitchell said: One wonders if the additional inhibitors etc are happy to intermix Easiest analogy is car car anti freeze. You can mix manufacturer but not the chemical makeup up. Car antifreeze is easy, as it's colour coded, blue, orange etc. the colour determines the chemical makeup up. If you try to intermix chemical makeup you are asking for trouble.
kandgmitchell Posted October 27, 2025 Author Posted October 27, 2025 Ok looks like I'll have to get a definitive answer as to what was used then.
