Screeders due in few hours... Forgetten power/ speaker wire runs - Help
Hello folks. I have around 250mm of insulation with some water pipes underneath and UFH pipes installed on top.
I've just realised I need networking / power and speaker cable to next to my sofas and kitchen island.
See above pictures, do I panic cancel the screed company who are due at 9 or is there something I can do in a few hours before they arrive?
If you are unable to fit the cabling now, fetch some 32mm ducting from somewhere and lay that, feed a drawstring so you can pull through the cable later.  Lay it as straight as you can.
Wickes or equiv, will do all you need.... Small drainpipe (for shed guttering etc) , and or white sanitary drain pipes would work as Ducting as well.
Use duct tape to seal the joints together,to avoid any liquid seeping in.
https://www.wickes.co.uk/Products/Heating+Plumbing/Plumbing/Waste-Pipes+Fittings/Solvent-Weld-Pipes+Fittings/c/1000550
They open at 8ish, so grab, go and push fit, and you'll be having a cup of coffee by the time the screeders arrive!!
Edited by Andehh
For what it's worth.... I was in the same situation when I realised my wall mounted TV in the lounge, I'd forgotten to put Ducting in to the corner for my AV Amp, sky box etc... Realised just as the Plasterboarding started in the next room.
I panicked out of work, was half way to screwfix when the site foreman raided the plumbers supplies and channeled out the wall for the pipe to be installed, and saved my day!
11 hours ago, boxrick said:
What would you hold it down with?
I'm worried it will float. Also got potential crossing of UFH
Go on then, what happened!?
Post up some pics
Mad rush to screwfix.
I got a few ducts in one location but not the other... threw them in as they were pouring the screed.
Better than nothing..
IMG_5557.thumb.jpeg.c7849d803d6581ef03116de7a645ec9e.jpegIMG_5556.thumb.jpeg.b45f27d0a8f6d0af736086ae7f82b2a7.jpegIMG_5555.thumb.jpeg.14a6697455b70e9ec78ebfc1ba32e4ae.jpegIMG_5554.thumb.jpeg.46b2f60e1a0acccd6c612dfe0dd38853.jpegIMG_5553.thumb.jpeg.a42b0ebd156c2e5b2f23a456c4cd99f1.jpegIMG_5552.thumb.jpeg.4fffa0666cbe9fbed8bfb8e7c4807b88.jpegIMG_5551.thumb.jpeg.0cc22e919e155b13e890a563be5e6430.jpegIMG_5549.thumb.jpeg.be0073f6c3c12397174de950df4bfc8b.jpegIMG_5548.thumb.jpeg.62295ec83a2637e1f08d47d5ed2ead2a.jpeg
