LSB Posted September 3, 2025 Posted September 3, 2025 Hello We have an internal wall that will support the roof, these are 7.3 150 * 215 * 440 (so wide) hollow concrete blocks. What's the best way to join a 90 degree intersection with standard size blocks which are thermalite. These To these The concrete ones will be filled with mortar and will be the top of the 'T' for internal walls and the vertical of the T joining the cavity wall. rough picture below. The cavity wall also goes the bottom side of the celcon. Do we use one of these Or, tooth the blocks into each other.
