amin Posted August 14 Posted August 14 Not sure if this is the right place to post, but I’ll start here. I’m rebuilding my roof as part of a loft conversion and also installing MVHR, so I want to make the roof as airtight as possible — ideally all the way from the eaves (where I’d like to run ducts between the eaves and dwarf walls). It’s a solid brick Edwardian house. Also in a conservation area so can’t do a warm roof due to the build-up and have to preserve what it currently looks like. My planned build-up is full-fill mineral wool between rafters, with PIR insulation underneath. What I’m struggling with is where the airtight layer/membrane should go, and how to detail it around all the penetrations from rafters, joists and the joining it back down to the wall from the room below. What’s the best approach here? I feel like it’s a huge puzzle piece trying to get that membrane in and I must be missing something simple here. I’ve attached a detail of what I’m aiming for (apologies for the rough SketchUp drawing!) mineral wool roof.pdf
Redbeard Posted August 14 Posted August 14 Hello, Why is the Intello to only come 'up to 400 above the joists'? If you continue it all the way from one side to the other, and do all the details correctly then there is your answer to 2 hours ago, amin said: where the airtight layer/membrane should go, and how to detail it around all the penetrations from rafters, joists and the joining it back down to the wall from the room below. I have not used Solitex Plus before, so I assume you know (as I don't) that it is deemed OK by the manufacturers for venting *above* rather than *under* the membrane? I would have vented below the membrane, but that's just because I am a 'dinosaur'. You say you 2 hours ago, amin said: can’t do a warm roof due to the build-up and have to preserve what it currently looks like but your counter-battens assure that it will not look as it currently looks, surely? I see why you want to vent above the membrane, to keep the 'lay-up' thinner, but if that's at the expense of upsetting the conservation officer then it doesn't achieve much. Have you agreed the roof rise with the CO? Your reference to penetrations and integrity of the a/t layer suggests that you already know it will be a PITA to to all the cutting, priming and taping. It is, though, exactly what I would do. Taking it down into the room below could leave an unsightly 'blurge' of A/T tape at the top of the room, but if you chop out the plaster at the top of the wall you could (a) before the taping of the membrane round the joists, put a thin (say 6-10mm) coat of lime plaster on all the brickwork then, when it has gone off, prime it and tape the membrane onto it with one of the 'plaster-onto' tapes. Then do just that to finish.
amin Posted August 14 Author Posted August 14 Coming up 400mm from the joists was partly because it feels like I’m doubling up on VCL with the foil face of the PIR which I would want to tape up - I’ve assumed that provides a good layer of airtightness still? On the counter battens you’re right to point out the counter battens issue - at 25-38mm it will definitely be a build up. But this in my view will barely be noticeable from street level vs adding insulation layers on top? On solitex it’s a diffusion open membrane so venting above should be allowed - I’ve stuck to the pro-Clima product given the intello membrane inside. Sounds like there no way round getting a/t membrane in will just be a PITA and no shortcuts I’ve got the house back to brick so have flexibility on the room below. @Redbeard how would you approach it if you were to design it?
Iceverge Posted August 15 Posted August 15 A quick doodle. Parge the brickwork behind the mineral wool as your airtight layer. Join it to the red airtight membrane that runs between 2 wall plates to protect it and up the top of the OSB on top of the rafters. Tape the OSB as your airtight layer. Add PIR on top and mineral wool below. I would prefer something like a dense EWI style mineral wool like Rockwool Frontrock if you can source it. Add stub rafters with long screws to extend roof. This detail makes airtighess simple and extra robust for following trades to bring services up from below and route them in the rafters. I'm a big fan of having structural timber warm behind insulation too. Far less thermal movement etc. From the top 1. Roof tiles 2. Tile battens 3. Counter battens 4. Roof membrane 5. 100 mm insulation 6. 11MM OSB taped at all joints 7. 150mm rafters with mineral wool. 8. Plasterboard and Skim.
amin Posted August 17 Author Posted August 17 I like this idea. In terms of building it would this raise the height of the roof above where it is currently? Already a bit over with counterbattons as it stands so don’t really have scope to push any further. Also given the rafters underneath will need to be 150mm I’ll likely need what looks like a “reverse” birdsmouth - is that structurally acceptable? Alternatively can I run the osb layer somewhere else maybe above where the existing rafters are maybe?
amin Posted November 22 Author Posted November 22 (edited) As an update on this, I managed to get some details designed to push the rafters back and that gives me the option of getting 100mm insulation over the top. @Iceverge your suggested buildup - is this an issue from a condensation pov with having the less breathable material (PIR) above the rafters? This thread here seemed to generate quite a bit of debate and left me a bit confused on how to think about it. I would like to avoid having PIR between rafters given how tricky it is and the detail required. Also what about the VCL in this buildup? Edited November 22 by amin
Iceverge Posted November 23 Posted November 23 The roof will be able to dry inwards. I would just tape the OSB for airtightness and leave it at that. You could sandwich a VCL between the OSB and PIR but it's unnecessary in my view.
