Tim C Posted June 30 Posted June 30 Hi everyone, I am looking for some advice and product recommendations for laying 20mm 600x600mm porcelain tiles onto an external reinfoced concrete sub base patio/path. There doesn't seem to be to much info online for this method as most folks go with a sand/cement bed There are two sections, the first is 40 sqm rectangle and the second is a path of about 20 sqm (2 m wide). Here's what I was thinking: Plane the concrete which is currently a bit lumpy in places Apply primer Level where needed with Keroflex LevelFlex External levelling compound (i.e. not a latex product) Use an S1 tile adhesive such as KeraKoll Setaflex standard (would S2 be better?) Grout with Ultrascape flowpoint Wasn't sure if I need to factor in some expansion joints on the main 40 sqm patio (4 x 10m), but could easily do this. Thanks for any advice, tips or product recommendations!
Nickfromwales Posted June 30 Posted June 30 I’d prob just level and lay with the adhesive, if the bumps aren’t >5mm. Other than that you’re on the right track. If the tiles are dark and get a lot of sunlight you may need to put one expansion gap in across, to divide the longest length.
Tim C Posted July 1 Author Posted July 1 Thanks Nick, that’s reassuring feedback. yes, tiles are dark grey and the patio is south facing so certainly get’s warm. In fact, was like the surface of mars yesterday as I was planing the slab, so will factor in some expansion joints. if anyone else out there has product recommendations then that would be appreciated before I purchase a lot of materials.
Andehh Posted July 1 Posted July 1 Anti crack mat for sure! We installed one, and still see a few cracks in the grout which need redoing, but touch wood no other issues. Similar sqm to you, laid in 75mm ish sand and cement.
